decents heads for t2 cam?
Old Jun 11, 2006 | 06:20 PM
ls2 bait's Avatar
Default decents heads for t2 cam?
what would be a decent overall head for a torquer 2 cam? something that would get my dcr maybe a little closer to optimul and maybe even give me a tad more compression? im not trying to break the bank but if something is worlds better than others let me know.
Old Jun 11, 2006 | 08:13 PM
JZ'sTA's Avatar
Ur gay.
I cant figure out why you dont just ask me.
But since you didn't now I am not telling.
Old Jun 11, 2006 | 08:19 PM
98Z28MASS's Avatar
prc ls6 tsp heads with the additional porting/livernois ls6 heads/patriot ls6 heads...any of the 3 will do great with the t2.
Old Jun 11, 2006 | 08:47 PM
IVRedZ28LS1's Avatar
I'm about to install some 5.3 ET performance heads on my 98 Z with the Torquer cam. Has anyone used these set of heads before? Would like to know.ThANKS.
Old Jun 11, 2006 | 09:15 PM
ls2 bait's Avatar
Originally Posted by JZ'sTA
Ur gay.
because i know what ur answer would be. et heads or the 5 extra pair of ls1 heads u have laying there
Old Jun 12, 2006 | 03:15 PM
JZ'sTA's Avatar
Acturally I know you better then that and I know your not trying to spend ET money. (Although if you were I would defentially suggest them)
I also know that your trying to get a better head then the extra sets I have siting around.
I would suggest the ET's but for a cheeper rate I would suggest either the Dart 205's, TEA stage 1 LS6 heads, or TSP stage 1 heads with their comp valve job. (For the 100 bucks I would always get the valve job)
The stock valves work pretty well so there is no reason to spend the extra money on the valves in your position.
Give me a call or swing by I will do what I can to help you make the right decision.
Old Jun 12, 2006 | 05:53 PM
ls2 bait's Avatar
t.t.t.
Old Jun 12, 2006 | 06:28 PM
Quik's Avatar
im running 243 castings on my 6litre with my T2 cam makes me around 11.1 and 8.12
Old Jun 12, 2006 | 08:26 PM
RoastEmSS's Avatar
prc stg. 1ls6 w/valve job here. dyno numbers/track times soon to come
