lets try this again
Old Jun 13, 2006 | 10:49 PM
Wnts2Go10O's Avatar
Default lets try this again
jp performance double roller, cant get it on, its like the chain is too short. i knw how to install these things ive jus never had this problem. ideas?
Old Jun 13, 2006 | 11:05 PM
jermzz's Avatar
1. compare it to the one you took off and see if its shorter.
2. get a new one, if its the same size, send it back cause thats not the prlblem
3. how are you putting the chain on? ive always had to put the chain on the gear then align the cam dowl.
Old Jun 13, 2006 | 11:16 PM
Wnts2Go10O's Avatar
im trying to do it the exact way ur describing in 3 but i dunno wtf is going on. m jus trying to not cross thread the holes in the cam
Old Jun 13, 2006 | 11:22 PM
jermzz's Avatar
Use a waterpump bolt to pull the cam forward. it will be really close but it should thread in strait... it doesnt go strait over the hole?
pics?
Old Jun 13, 2006 | 11:37 PM
Wnts2Go10O's Avatar
pics?
ill get pics if i can find my camera. the cam gear when in the chain doesnt want to line up with anything on the cam. its such a weird occirance that its almost embarassing to post the problem.
Old Jun 13, 2006 | 11:49 PM
Wnts2Go10O's Avatar
water pump bolts wont work. the farther away with the chain on i go the more angle there is and it go in.
Old Jun 14, 2006 | 12:00 AM
jermzz's Avatar
Is there a ***** in your chain on the crank gear? lol. Look at it close and make sure it's not stuck there somewhere, that happened to me. make sure theres one tooth per link. If thats all right and it wont reach then there is some other issue and i'd maybe try a different chain?
Old Jun 14, 2006 | 12:03 AM
Wnts2Go10O's Avatar
both chains are the same length. ill check one more time after im done munching.
Old Jun 14, 2006 | 12:11 AM
Wnts2Go10O's Avatar
ok so it fits on the bottom gear but nothing lines up.. i can pu the gear on without the chain but i cant get that sobon there with the chain. wtf?
Old Jun 14, 2006 | 12:36 AM
Wnts2Go10O's Avatar
ttt...
Old Jun 14, 2006 | 02:13 AM
Wnts2Go10O's Avatar
bumpidy
Old Jun 14, 2006 | 01:53 PM
Wnts2Go10O's Avatar
bump
Old Jun 14, 2006 | 03:46 PM
Wnts2Go10O's Avatar
ttt again
Old Jun 14, 2006 | 04:45 PM
ringram's Avatar
See if there is anyone local to you who can drop by to help out!?
Old Jun 14, 2006 | 05:40 PM
Wnts2Go10O's Avatar
pictures of problem...if u can see what i mean.
Attached Thumbnails lets try this again-problem-003.jpg   lets try this again-problem-004.jpg   lets try this again-problem-011.jpg   lets try this again-problem-013.jpg   lets try this again-problem-012.jpg
Old Jun 14, 2006 | 06:16 PM
Wnts2Go10O's Avatar
ttmft again
Old Jun 14, 2006 | 06:53 PM
Wnts2Go10O's Avatar
ttt...
Old Jun 14, 2006 | 09:12 PM
P Mack's Avatar
When I did my double roller I thought my chain was too short. Turned out I had pushed the crank gear on too tight so the chain was wedged up against the block and wouldn't wrap as far around the crank gear as it needed to, which made it look too short. That doesn't look like your problem from the picture but i guess you could try pulling the crank gear out a fraction of an inch and see if it goes on then.
If that's not it, make sure the cam is pulled forward all the way, it can slide back a quarter inch or so into the block so you have to keep it pulled forward. Then try to get a single bolt started. Then use a ratchet handle or something in the hole in the camshaft to pull the cam gear up to get the other two holes and the dowel to line up.
Old Jun 14, 2006 | 10:40 PM
Wnts2Go10O's Avatar
thx ill give it a try
Old Jun 14, 2006 | 11:07 PM
Wnts2Go10O's Avatar
ok, the od set and new set are 1 3/4" in length. id like to know the clearance measurement on the stock crank gear if anyone knows. ive noticed something else, the chain seems to not have any interferance but is only fully seated on a couple teeth on the crank gear. i dont think theres a clearnace issue, i dont wanna have to tke it off again
