Lobe Sep Angle
Old Jun 29, 2006 | 08:53 AM
c5_ls1_6spd's Avatar
Default Lobe Sep Angle
between a 112 and 114 LSA, correct me if i'm wrong, but is it true that on a 112 LSA, power comes on sooner than if on a 114LSA?
Old Jun 29, 2006 | 08:55 AM
GA/TA's Avatar
Yes i believe you are correct.
Old Jun 29, 2006 | 09:10 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
No question about it. You are correct.
Old Jun 29, 2006 | 09:11 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That 114+ will spread it out more over the band.
Old Jun 29, 2006 | 09:13 AM
Patrick G's Avatar
LS1 Tech Administrator
Yes and no. Power/torque peaks are mainly determined by your intake valve closing point. A later IVC will typically give you a later power/torque peak.
If you take the exact same duration and only change the LSA, a 114LSA cam will have a later power peak. But look at this:
224/224 112LSA (+0) = IVC 44 degrees ABDC (6200 rpm peak)
224/224 114LSA (+0) = IVC 46 degrees ABDC (6300 rpm peak)
But when you add advance to it:
224/224 114LSA (+4) = IVC 42 degrees ABDC (6100 rpm peak)
Notice? Wider LSA, earlier power peak. Intake centerline is another really important consideration in determining where your power/torque peaks. I haven't even included duration into this equation (which would take a few more paragraphs to explain).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jun 29, 2006 | 09:16 AM
Gearhead1's Avatar
OK, this has been on my mind for a while now, so I'm finally going to ask. What formula is used to determine the power peak of a given camshaft??
Old Jun 29, 2006 | 09:17 AM
Patrick G's Avatar
Experience.
Old Jun 29, 2006 | 09:27 AM
Gearhead1's Avatar
Experience.
That's the one formula I don't have access to!!
Old Jun 29, 2006 | 09:33 AM
ahhhh, that exactly what i was looking for....... so the 114 has a broader powerband and the 112 has a narrower power band?
Old Jun 29, 2006 | 11:52 AM
PREDATOR-Z's Avatar
Experience.
Nice one, hehe
Old Jun 29, 2006 | 03:32 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Technically...until you get technical.
Old Jun 29, 2006 | 04:25 PM
Viper's Avatar
It is sooo cool search is back up:
https://ls1tech.com/forums/showthrea...lobe+sep+angle
Old Jun 29, 2006 | 09:04 PM
Biggs's Avatar
Experience.
AMEN to that
