Camshaft Install Problem
Old Jul 1, 2006 | 10:02 PM
luedecke09's Avatar
Default Camshaft Install Problem
Alright after getting my camshaft through the first two bearings it wont go through the third, i'm not about ready to force it through either. Any idea why this is happening? I tried another camshaft and same thing happend. This is an LS6 block with Clevilte 77 bearings
Old Jul 1, 2006 | 10:13 PM
my01camaroz28's Avatar
If you can look down the center and see no obstructions you should make sure the cam is lubed up good and keep trying. I found that the last few cam swaps I did for friends hung a little and it was fixed by turning the cam with a little pressure and keeping it centered.
Old Jul 1, 2006 | 10:16 PM
USMARINE1108's Avatar
Are you turning the cam as you put it in?
Old Jul 1, 2006 | 10:24 PM
luedecke09's Avatar
Yes i'm turning it and it has Mobil 1 on it, i just dont want to harm my bearing and or camshaft. How much pressure are we talking?
Old Jul 1, 2006 | 10:28 PM
2002 SS #476's Avatar
Is a lifter blocking it? If you got it that far, it should go right in.
Old Jul 1, 2006 | 10:29 PM
Wiggle it while turning and pushing. Back out a touch and try some more. You could be catch a lube/stick pocket where suction from fluid grabs it. Kinda hard to explain the force. But wiggle and push, but not real hard. If it is sticking you are still ok.
Old Jul 1, 2006 | 10:32 PM
luedecke09's Avatar
Default hmmm
alright I will go out and try again thanks for all the help guys
Old Jul 1, 2006 | 10:38 PM
eallanboggs's Avatar
It also helps to have a looong handle to be able to leverage the cam from side to side and up and down as you're rotating it and pushing it in at the same time. The longer the tool the better. Lube helps too, but so does a certain amount of patience. I drilled a piece of flat stock and welded a 2' rod to it. Once the tool is bolted to the cam I hold the tool at both ends. With you hands that far apart you have better contol over the cam and you can make it move more precisely which is what you need to do to get the journals thru the bearings.
