First Cam Install
and it works perfect!! best money ever spent on a tool! Also used the Crane valve spring compressor, I would suggest using this one to do springs, can't beat doing two at once and not having to use one hand to hold them compressed and I used TDC method for keeping the valves up. I followed the write up on ls1howto, and haynes manual, I can honestly say the ls1howto covered EVERYTHING!, I personally did not find anything wrong with it or that was diffrent than the haynes said, it was perfect, who ever wrote that needs an endless supply of beer! Sorry so long, just wanted to share my experience!! DISCREPANCY: LOW HP, GETTIING BEAT BY STOCK BLOWN COBRAS
CORRECTIVE ACTION: TROUBLESHOT TO CAM AND EXH MANIFOLDS CHOKING LS1. R2 CAM I.A.W. T.C.T.O. 224@.050 .563/112+4. R2 MANIFOLDS IN PROGRESS. FURTHER MAINTENANCE REQUIRED.
Ya I didnt even notice that I put that in there!!, everyone must be thinking "what the hell!!!" E&E here!! I better go get this out of cams before I get yelled at!! Trending Topics
PM sent
i used the same ls1howto directions and haynes manuel also and they had everything down perfect (even warned you when you will be cussing
)only things that slowed me down was definitely that crank pulley (4" pulley puller did wonders though) and that damn oil pump. when i saw the the oil pan needed to be drop, so did my mouth, but it really wasn't that bad. getting the pump off was a bitch with a few jerks and tugs here and there... are the lifters really that bad?... they're next
