Dynamic compression calculator.
Old Jul 5, 2006 | 07:39 PM
redtail2426's Avatar
Default Dynamic compression calculator.
Wheres the easiest one to use??
Old Jul 5, 2006 | 07:49 PM
ufsnola's Avatar
This is a pretty simple one I use, plus site has good info.
DCR Calculator
Old Jul 5, 2006 | 08:22 PM
gollum's Avatar
Heres one:http://www.kb-silvolite.com/calc.php?action=comp
Old Jul 5, 2006 | 09:15 PM
Beast96Z's Avatar
Originally Posted by gollum
That's the one I keep in my favorites.
Old Jul 5, 2006 | 09:16 PM
jinxedz's Avatar
LS1 values?
Old Jul 5, 2006 | 09:38 PM
rhamm1320's Avatar
http://www.virtualengine2000.com/DCRCalculator.htm
Old Jul 5, 2006 | 10:02 PM
Xtnct00WS6's Avatar
This one seems to be good:
http://www.alantripp.com/VE%20Calcul...y%20Lookup.xls
Old Jul 6, 2006 | 09:35 AM
gollum's Avatar
This is very interesting.
http://speedtalk.com/forum/viewtopic.php?t=1372
Old Jul 7, 2006 | 03:36 PM
Viper's Avatar
On this one:
Do you use -2 for piston cc if you have valve reliefs?
And if my ADBC @ .050 is 44.5, then I use 59.5 for the calculator?
63cc heads, .052 gasket (compressed value I assume)
Puts me at 11.2 and 9.2.
Old Jul 7, 2006 | 06:09 PM
Viper's Avatar
OK, got this:
That's were you guys are messing up. Your supposed to figure your IVC at .006" first thing before even going to the sight. For this, you will need your .006" intake duration and your ICL. Take your advertised, for example, it's 294, divide that by 2, then add your ICL, then subtract 180. This will give you your IVC at .006". So 294/2+112-180=79* IVC @ .006". The KB sight says to "add 15" to your .050" to get your IVC at .006", but that dosen't work on our cams. It's all about getting the right info first.
So my IVC is 70, which puts the DCR at 8.1
(278/2+111)-180=70
