Tsp cam?
Old Jul 20, 2006 | 12:08 PM
01BlackCamaroSS's Avatar
Default Tsp cam?
Texas Speed 228R Camshaft is this cam good for my set up im getting Lt's ory and a converter installed and wanted to get cam done at same time i was looking at either the 228r or the 224r and would it be a good idea to get the pacage with the cam the springs and the pushrods for $589.99 or can i jsut go with the cam
Old Jul 20, 2006 | 12:24 PM
RoastEmSS's Avatar
get the package. and get cam bolt and gasket kit, and a pulley, and a ported ls6 oil pump, and a ls2 timing chain
Old Jul 20, 2006 | 01:01 PM
PREDATOR-Z's Avatar
To change a cam you'll need:
Cam
Springs (either 918 Comp Cam) or PRC duals
7.425 Comp Cam push rods
Basic cam change gasket kit (with crank bolt)
Ls2 timing chain (if you have over 50K miles on your motor)
You'll need a spring change tool, oil, filter, assembly lube, RTV gasket sealant, 10mm ratchet wrench, breaker tube and bar (to beak loose crank bolt), pulley removal tool, assorted sockets and wrench.
As a guide read http://www.ls1howto.com multiple times.
once it is finished you still have to tune (wideband dyno being the best)
So in all budget at least $1500 to do it properly, along with lots of patience and a first aid kit for your poor hands
slow trap's Avatar
i second,if you have the funds now would be a good time for an ls2 chain,ud pulley and a ls6 ported pump.
Old Jul 20, 2006 | 01:29 PM
is the oil pump and timing cahin nessecary
Old Jul 20, 2006 | 01:33 PM
PREDATOR-Z's Avatar
Like I said, only if your car has over 50.000 miles.
Old Jul 20, 2006 | 01:36 PM
SRpwred240's Avatar
My car has 50,000 miles on it and the guy at Thunder said dont need to worry about it, but I still probably should get the chain.
Old Jul 20, 2006 | 01:51 PM
what if im at like 48000 im pretty close to 50 u think i should go ahead and get the oil pump
Old Jul 20, 2006 | 01:53 PM
what do you guys thinnk about the 224r and 228r , are the good cams im new with the hole cam thing and am trying to get somethign that will be a good DD
