View Poll Results: What is a safe RPM for a stock bottom end with aftermarket springs?
6300 RPMs
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
38
8.46%
6400 RPMs
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
25
5.57%
6500 RPMs
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
89
19.82%
6600 RPMs
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
44
9.80%
6700 RPMs
![](https://ls1tech.com/forums/images/polls/bar6-l.gif)
![](https://ls1tech.com/forums/images/polls/bar6.gif)
![](https://ls1tech.com/forums/images/polls/bar6-r.gif)
45
10.02%
6800 RPMs
![](https://ls1tech.com/forums/images/polls/bar1-l.gif)
![](https://ls1tech.com/forums/images/polls/bar1.gif)
![](https://ls1tech.com/forums/images/polls/bar1-r.gif)
118
26.28%
6900 RPMs
29
6.46%
7000+ RPMs
61
13.59%
Voters: 449. You may not vote on this poll
Safe RPMs on a stock bottom end with springs
#42
Originally Posted by Gauge
I seem to be getting largely varying answers to this question, so I thought a poll would be prudent. If you've got a set of aftermarket springs (Crane Cams double springs, in my case) but a stock bottom end, what is a safe RPM to rev the car up to?
As for the oiling system, spending the money on a good blueprinted pump is cheap insurance when turning the motor to that kind of RPM and comparing it to starving the motor for oil should your pump be wearing out or contaminated with debri from past mileage. My car (on the motor.) sees 66-6800 RPM pretty regularly without issue and it is a 2000 model. There are always theories about issues such as these until someone goes and does it on a regular basis. You can be sure the gets who are running there stock bottom ends over 7-grand are not practicing witch doctors. Hope this helps.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Jim C.
Originally Posted by just1news6
Good lord 7400 so explain to me how some spin to 7400 and are fine yet when people bounce off the rev limiter at 6200 they spin rod bearings???
The rev limiter issue is not really the key factor in spinning a bearing in one of these particular motors even though I would try not to make a habit of it. Hope this helps.
Jim C.
#43
Originally Posted by Big Geek
You can be sure the engineers at GM tested them WELL beyond we would just to find the answer to your exact question. If they are willing to set the REV limiter on the Z06 at 6500 then you can be sure they are confident they will last well beyond 7000 RPM.
#44
6800 RPMs here and I use RP 10-30 oil. They say change synthetic every 5 or 6K? I change mine every 3 or when it gets kinda dark what ever comes first. I also have a very early 2000 model like 12-99 or something like that. I've also been informed the hotter metal gets the softer it gets too so I run a 160 stat to keep things cooler too.
Another thing I heard some where before is that you ant at least 8psi of oil preasure for every thousand rpm, although I dont know how accurate that is considering my old LT1 saw 140K of abuse (and I mean abuse) and with the pennzoil 10-30 synthetic I ran the most it ever saw was like 42PSI.
#45
Originally Posted by blkZ28spt
I'm not sure I buy that logic. 700+ rpm over what they set the limiter at is quite a bit.
Jim C.
#46
I had the limiter set to 6800 on my last car, it did fine, so I'm going with that on this one when I get the heads/cam installed. When you think about it, it's the same rodbolts that the ZO6 has and the limiter is set to 6500. So do you think that GM would have the limiter at the ragged edge? NO WAY. Another 300 rpms isn't gonna go from GMs "safe" to grenading the engine. I am talking about 01 and 02s with the upgraded rodbolts.
#47
Location: Your girl's back door giving her the long stroke while you're at work
My limiter is set at 6700 and it shifts @ 6400. It's saw the limiter a bunch of times due the trans slipping before the the rebuild
#51
Originally Posted by gametech
As long as you swap the pushrods, I see no problem with 7krpm, even on a high mileage motor if properly maintained.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
He acted like he was deaf or something. He was lucky he didn't get fragged.
#57
I've heard a story for years that when GM was developing the LS1 that they ran a whole room full of engines at WOT [6,200 rpm's] for 500 hours without a single failure. The original design parameter was 50 hours but they continued for 500. If true, these engines can take a lot of abuse.
#58
my rev limiter is set to 7100 but I rarely take it over 6500.
ive swapped out springs, pushrods, seats, retainers, everything in the valvetrain but the lifters and the valves. most knowledgeable people ive talked too seem to think 7K is not too bad for a well maintained LS1. Good oil of course mandatory.
