cam install help
Old Jul 25, 2006 | 10:26 PM
mxmccarter2401's Avatar
Default cam install help
i'm gathering parts for a cam install is this what i need to replace(link). is it timing chain and gears or just the chain.
http://www.sdpc2000.com/catalog/4554...ming-Chain.htm
Old Jul 26, 2006 | 12:14 AM
ALBurgZ28's Avatar
The LS2 chain is what to go with.
http://texas-speed.com/shop/item.asp...=620&catid=53: Chain
http://texas-speed.com/shop/item.asp...=621&catid=53: Gears plus chain
Old Jul 26, 2006 | 01:32 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Don't forget retainers, pushrods, springs and possibly oil pump.
Old Jul 26, 2006 | 10:16 AM
thanks a lot guys
Old Jul 26, 2006 | 10:49 AM
Joel_SS's Avatar
yep go with the LS2 chain. bu what you linked to at SDPC is just a chain.
Old Jul 26, 2006 | 11:06 AM
97MysticZ's Avatar
What's a Sticky?
Does everybody usually just replace the chain, or the gears and chain??? Does the LS2 chain fit on the LS1 stock gears???
Old Jul 26, 2006 | 11:07 AM
Beasst8's Avatar
I got the sprockets and the chain.
Old Jul 26, 2006 | 11:10 AM
97MysticZ's Avatar
What's a Sticky?
How big of a pain is it to change the crank sprocket??
Old Jul 26, 2006 | 12:58 PM
BriGuy's Avatar
It's not that bad at all to change. The puller I rented was a tad big for the application but I got it to work.
Old Jul 26, 2006 | 02:33 PM
Long Beach's Avatar
Im currious myself if the ls2 chain will fit on the ls1 sprocket?
Old Jul 26, 2006 | 11:54 PM
ALBurgZ28's Avatar
Yeah, it will. I just did the LS2 chain on my stock ones. The chain is just a bit thicker.
Old Jul 26, 2006 | 11:59 PM
Arizona Mike's Avatar
Which pump is recomended?
Mike
Old Jul 27, 2006 | 12:09 AM
ShevrolayZ28's Avatar
Mike
The ported LS6 pumps are very popular.
Old Jul 27, 2006 | 12:14 AM
fastest94v6's Avatar
def. an ls2 chain and ls6 ported oil pump..
