ETP 215's VS TSP PRC 200cc Terminator Heads or others for a 346
Yeah I have a 02 z06 with a ms3 cam, long tubes, ud pulley, air intake, catback, tune. I want to stay n/a. So I hear that ET makes some of the best heads out there but I was wondering if there would be any difference in numbers between the ET 215's and the texas speed prc 200cc terminator heads? Which would be better to go with? I am trying to get over 500 to the wheels so keep that in mind. Also, I am not conscerned about $$, I just want the best possible hp/tq. Thanks guys.
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Beast, since he has a 346 wouldn't it make more sense for him to go with the ETP 215?
The ETP 225 flow numbers on a 3.900 bore are the same as a ETP 215 on a 3.900 bore.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
The ETP 225 flow numbers on a 3.900 bore are the same as a ETP 215 on a 3.900 bore.![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Arrow](https://ls1tech.com/forums/images/icons/icon2.gif)
Originally Posted by Beast96Z
Didn't know the numbers were the same. If that is the case, then yea, the smaller runner should do better. Not quite sure why a 10cc bigger head would flow the same though. I'll have to go take a look at that. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
https://ls1tech.com/forums/showpost....1&postcount=39
Here's the whole thread.
https://ls1tech.com/forums/showthrea...&highlight=etp
what did you make with a ms3 cam, long tubes, ud pulley, air intake, catback, tune to the rear wheels?
Yeah I am trying to figure what heads are best for my 02 z06, thus far I have kooks long tubes, varam intake, ms3 cam, borla stingers catback,underdrive pulley, tune. I want to get over 500 to the wheels all n/a. What would be the best heads to go with? $$ doesnt matter, I just want the best numbers.
I too am interested in how much power you make now, I know how much you can gain with the TFS heads and Fast intake, give me a call and let me take a shot at making the power you want.
Going with the ETP's will allow you to run higher compression without flycutting....I think as much as 12.5:1, but when C/R goes up it "usually" requires more octane or less timing.....
If money is no object I suggest the ETP with Jesel rocker arm setup, and you're gonna need the full assortment of bolt-ons including an EWP, and a fully ported Fast/TB(speak with Tony Mamo of AFR).......
Good luck!
Good luck!
Why dont you go with a already proven setup like TTP or Cartek. Both of these shops have cars in the 500RWHP range. Cartek has been building some of the fastest cars for many years now.
