ARP Studs/Bolts & Cylinder Warping…
What is the actual risk factor involved when using ARP head studs or bolts without align honing the cylinders?
Any chance of warping the cylinders?
Old small block Chevys had the head bolt holes so close to the cylinder wall that "torque plate honing" was required, due to the studs deforming the cylinder wall next to the stud.
LS1 engines don't really require "torque plate honing" due to the bolts being so far away from the cylinder wall.
So to answer your question, you will not have a problem if you decide to use head studs.
So, we are still pretty undecided. Anyone else have something to add?
My engine doesn't currently have any 'piston slap' issues and I'd rather not give it some. I see a lot of people using ARP studs though.
I believe people have their blocks machined at the same time they install the studs though, and you only have to install the studs once, heads/mains, so... It would make sense on a new build to install studs and have it machined, better safe than sorry! If you can get a set of studs, torque them down, and check with a dial bore gauge, you will see if it is distorted or out of round. I really wish I could help you more bud, I just put my studs in tonight, to find that the set I bought (new) are missing 5 nuts!!! GRRRR >=| Good luck bud.
1 Post
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by Brian Tooley
I think you may be confusing "align honing" the mains when changing to main studs, as compared to using head studs.
Yea, I do think Brian would know. But all are valid opinions.
I will probably go with the studs because I'm sure I will have the heads off again for something.
Thanks!
Thanks!
