W1 Camshaft in a 112 LSA?
The entire specs of the cam are 227/234 578/589 on a 112 lsa. And if speedtek sells this camshaft why would you say I could find a better thought out cam. I have herd great things about this camshaft for cars that are on spray. And seeing how I have a 150 shot I think that includes me.
I would never run a speedtek cam. The last several that we have installed have lost power or gained nothing but about 10-15. They specialize in SBC and BBC for the most part. They are not that involved into the LS1 world. Therfore you will not find the most helpful place to be Speedtek. Why do you think that they are not a sponsor on here? They aren't going to be able to answer the questions that people call in and ask.
for the size of that cam, we made great power in both prototype cars it went into. The first cam went into John D's LS1 Fairmont station wagon, the 2nd cam went into my car. Both cars made sick power for stock heads on bottle. John made 580 through the stock 4l60E, I made 630 and 900 ft lbs through a t400 and 9"...stock heads, stock shorts, cam only with bottle setups....Both nitrous kits were Mustang style in which we added fuel pressure via a vacuum port on an adjustable FPR from Aeromotive. i was quite surprised at making 396 through my t400 NA...It ran decent NA as well with a 7.13 @ 97 at its best pass...
If you're going after a 112 lsa, you dont even remotely have a clue on what valve events do what for making power. Seek professional help. Not someone that works on a sale counter for any particular speed shop. Patrick G, J-Rod, EDC are the names that come to mind that are respectable and opinion count in this event at hand. Give them what you want to do with the car, and you will get a grind in return.
Id love to sit and explain all of the events and how the effect DCR, SCR, etc but they have done it over and over on putting it in terms that even a newbie can understand.
If you want to spray, and make big power with efficiency, get the W1. Dont change the LSA because you think it should be changed...it hits PLENTY hard on a 116....LSA does little for choppyness sounds...Duration has more role then anything on how a cam sounds...
The 112 LSA is not the cam grind ideal for you...It bleeds off some cylinder pressure and doesnt have as high DCR that could be used to make more power on bottle with the 116lsa...
Like I said. Its a one-off grind and is not the cam that made the sick power on bottle....The 116lsa version that speedtek has proprietory (sp) rights on is the one that made the power on my car and Johns wagon. ALthough, im not sure that its still ground by Comp...I think Keith may have switched to Lunati grinds which arent the same lobes we used with Comp....I believe the guy at Comp that Sam spoke to is no longer with that company as well. I know they spent a few weeks on the phone together coming up with the events and numbers they wanted. When we got the cam, we were very pleased....I quoted the numbers above. This was a cam that used for the 04 Thunder Event...I was still on an old F1 cam from them and loose hobart converter (5300..LOL was claimed to be a 4000 unit) I went 10.5's and John went 10.2's and then had to be towed home. The stock 4l60E took a dump.
