Its All Finally Installed!!!!
Old 08-07-2006, 05:00 AM
xxtheonlyxx's Avatar
Default Its All Finally Installed!!!!
I finally got it all installed!!!!!!!!!!!!!!!!
SLP lid,
SLP MAF
90mm NW TB
90mm Fast LSX intake manifold
AFR 205's
upgraded springs, push rods, and retainers
QTP long tube headers
QTP y-pipe w/high flow cats
Cut out/ flowmaster 3in 3 out 80 series catback
228/232 110+1 HR cam
yank 3200 stall
Strange 12 bolt rear end with 3:73's
After it is perfomance tuned, Im getting some ET streets and Im going to stop modding for a while... Can someone with a similar setup give me a rwhp estimate before I hit the dyno??
Old 08-07-2006, 05:12 AM
bmfcamaro's Avatar
did you get injectors? you will probably need them. at least svo 30's or safer 42's
i would say a little over 400rwhp with an auto, maybe 425
Old 08-07-2006, 05:32 AM
Thanks. I was going to upgrade the injectors but I was told by a couple of people not too. How would I be able to tell if the injectors needed to be upgraded... would the engine struggle at WOT at higher speeds????
Old 08-07-2006, 08:23 AM
2005suburban's Avatar
You could use a Scanning tool such as HP tuners... Which probably wouldnt be a bad investment with all that money you just spent....
You can see what kind of Millivolts there pumping out... Then go from there...
Old 08-07-2006, 11:32 AM
I would assume the factory injectors can hold up to 450rwhp. With a good tune I should be around 425- 445 which is cutting it real close. I'm just going feel it out and see how my car responds to the new mods before I go spending any more money just yet.... DAMN THIS CAR IS FAST NOW WOOOHOOO!!!!!!!!!
Old 08-07-2006, 11:34 AM
02NBMFormula's Avatar
should be pretty fast, id like to see a video of it, thinking about a similiar cam
Old 08-07-2006, 11:49 AM
I'll try to get one after my re-tune today.
Old 08-07-2006, 11:51 AM
v-8
v-8's Avatar
we need some track times...
Old 08-07-2006, 11:52 AM
SVT THIS's Avatar
I'd guess 425rwhp/410rwtq
I'd say you've got a solid 11 sec car there. How in the heck could you wait to install that all at once?!
Old 08-07-2006, 11:56 AM
Thanks, it was hard, but I really didnt have a choice. It took 2 months to get the strange rear end and QTP pipes. Plus the guys that installed it gave me a deal since it was easier to do it all at once. I already had everything but the heads, header, and cam in. It really woke up the 90/90 combo!
Old 08-07-2006, 11:57 AM
SVT THIS's Avatar
What are the lift numbers on that cam? That is a fairly large duration cam compared to the other ones I have seen with the AFR 205s (usually in the 224ish range). Those heads love big lift numbers!
I plan on taking it to the track after I get it dyno'd. I just ordered ET streets so I plan on doing some bird watching from the line
Old 08-07-2006, 05:08 PM
Billiumss's Avatar
Who told you that? Local people? I would use SVO 30lb injectors if I were you. Add them before you have your friend tune your car.
Old 08-07-2006, 05:15 PM
redtail2426's Avatar
yeah i would do svo 30's..your stockers will be at or over 100% duty cycle.
Old 08-07-2006, 05:27 PM
pdd
pdd's Avatar
congrats on the sweet setup i would also swap injectors
Old 08-07-2006, 05:57 PM
its .588/.595
Old 08-07-2006, 05:59 PM
I figured I would need them. I'll go order em now. Thanks everybody!
Old 08-07-2006, 06:21 PM
1stz06's Avatar
My set-up is almost identical to yours. AFR 205's milled .0020, 228/232 588/592 110+1 LSA, fast 90/ LS2 TB. I put down 440RWHP and 400 RWTQ (M6) WITHOUT an underdrive pulley or degreeing my cam. Plus, I have some crappy headers (TPIS) and that is more than likely why my TQ numbers are low. Getting these things corrected and Mamo velocity porting my intake, shooting for 455RWHP on stock LS6 shortblock.
Good Stuff.......impressive set-up!!!
Old 08-08-2006, 01:11 AM
Thanks!!! You have a nice set up too!!
Old 08-26-2006, 12:43 AM
I dyno'd at 420rwhp, and 371rwtq on an LS1 block with an A4. I need to upgrade my block so I can unlock some of this hp.
