MS4/Terminator heads...TSP guys come inside
how is life !!
I just ordered my new MS4 last night (239/242, .649"/.609 on 111LSA , PRC spring kit ,Hardened Chromoly Pushrods , gaskets& bolts) and i was thinking to match it with the new terminator heads... they come completely CNC ported & use PRC CNC valve job technology
What do u think guys? Is fly cutting a must with Terminators? Need advice
How much the Terminator going to cost me only heads (no springs) since i already got PRC spring kit (660 lift) that come with cam pkg.
TSP guys need help
Thanks -ISA-
TSP guys need help
Thanks -ISA-
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If using the MS4 you will need to flycut. You can run the MS3 w/ out P/V issues if using a stock thickness gasket, but you need to check anyway for safe measure.
The MS4/Edelbrock combo would make excellent power especially with more compression!
The heads without the springkit installed are $1650.00
If you guys need anything just let me know!!
i was going to post this , but it was already here with answers ... cant beat that. now i just need to find a place to do the flycutting. how to order the terminator heads(with valves) without springs ? i dont like using my telephone...
What would the P/V clearance look like if I was to mill the Heads to 58cc and use a piston with say a -2 or -4cc valve relief? I would like the extra compresion and will probably have the bottom end apart to add new ARP studs and rod bolts at some point anyhow.
A piston with a relief should not have a problem with P/V clearance no matter what chamber. Just let us know what size chamber you need and we will make it happen.
