cam only, 90/90 worth it?
Old Aug 8, 2006 | 08:04 PM
bad6as's Avatar
Default cam only, 90/90 worth it?
for a cam with both sides 235 or smaller would a 90/90 set up be worth it?
or would a pp tb and ls6 im be ok
Old Aug 8, 2006 | 08:14 PM
SSilverSSurfer's Avatar
i gained peak hp but not in my powerband so it hurt me kinda
Old Aug 8, 2006 | 08:17 PM
Patrick G's Avatar
LS1 Tech Administrator
Without ported heads, the extra flow benefits of the FAST intake are pretty minimal unless you turn LOTS of rpm. Once you're running ported heads though, the FAST 90 is an essential component to making more hp.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 8, 2006 | 08:20 PM
HOSS's Avatar
i gained 30 rwhp, and 10 rwtq with a pulley, cutout, and fast 90 setup. I gained a good but from the cutout b/c of my **** *** exhaust, but I would think that i saw 10-15 rwhp, doubt i saw any tq though.
Old Aug 8, 2006 | 08:24 PM
bad6as's Avatar
i would like 400rwhp and 400rwtq
so a ported tb and ls6 im would be fine
Old Aug 8, 2006 | 08:27 PM
HOSS's Avatar
Depending on what cam you go with, 400 rwhp will not be a problem with a ported tb and ls6, 400 rwtq will be very hard to achieve cam only, some people don't even see that with a h/c setup. Best of luck!
Patrick G's Avatar
400 rwhp is achievable cam only, but exceeding 400 lb ft of torque is very difficult unless you have a cam that gives you sky high dynamic compression.
__________________
Old Aug 8, 2006 | 08:28 PM
bad6as's Avatar
could the 230 224 from tr be close to that
Old Aug 8, 2006 | 08:33 PM
HOSS's Avatar
Around 400 rwhp yes, the tq would be good to be in the 380's. You have a 9" to, so its gonna be that much harder to get there. That 9" is gonna rob you of prob 8-15 hp if I am not mistaken. You may need to go just a bit bigger, but if you stick with Thunder, you will get closer to your cam only goal than you would with most others without having to go huge with the cam.
Old Aug 8, 2006 | 08:41 PM
eamador11's Avatar
No benefit. think of it like this... your blowing air into a 3" tube thats connected to a 1" tube. your not going to get the same amount of air because the 1" tube is a bottle neck;it can only flow so much.
same concept.
Old Aug 8, 2006 | 08:49 PM
Ksett's Avatar
You could buy some budget heads for less than what a 90/90 costs and have a little money left to put towards the LS6 intake.
Old Aug 8, 2006 | 09:21 PM
bad6as's Avatar
https://ls1tech.com/forums/lsx-parts-sale/554999-fs-custom-224-224-cam.html
check that cam out......
Old Aug 8, 2006 | 09:28 PM
ShevrolayZ28's Avatar
After I found out how little is gained and how much they cost, I went out to the garage and gutted my cats. When I was done I said, "There! There's five freebees!"
