thicker oil better for highway trip?
I was thinking about changing from 10-30 Mobil 1 to 10-40 Syntec before I take a trip. Would it be better for the engine to have the thicker oil in there. It is like 100 degress here also.
Run Castrol (ONLY the "Made in Germany" bottle) Syntec 0W-30. It is closer to a 40 weight and is actually thicker at operating temp than the 0-40 Mobil 1.
On this website they say the 10w-30 Mobile 1 is too thin for this engine and it more like a 20 weight. When I was using the 10-40 Syntec I did not have the engine noise I have now.
if noise is your concern id stay as far away from m1 as you can, once m1 hits 1,500 miles is like water.. castrol is a quieter oil, as is royal purple 10 w30 id use the rp its the best i have tried sofar, its pricey but it was deffinitely a vast improvement over m1 for me.
well, i would not say that m1 "is like water". I've seen oil analysis where it loses a little viscosity. I've gone 9000+ miles between oil changes (mostly hwy driving) and am doing fine. Calling royal purple better tham m1 is a huge stretch in my opinion. Go to bobistheoilguy.com , and check out the oil analyses there. As mentioned before, German Castrol is liked by a lot of people as well.
my oil pressure is at 40 psi at 500rpm's even hot its at about 38-40. for me rp is better because i dont like noise, my engine runs alot smoother on the rp.
if you say so but i think 15 psi drop in 2k is alot more then " alittle" when i first put in m1 it was usually about 30 35 psi at idle until after i put about 2k miles (m1 at 20psi at idle) the pressure at idle would only go lower the older the oil got, where as my rp i have yet to see any noticible drop in psi and i put about 3 k on the rp sofar...
If you're constantly in high temp locations (like desert SW) the thicker oil may be better. GM told the Bondurant school to use 15w-50 weight oil in their school cars (Z06s, CTSVs) after a couple of LS6 engines expired using the OE 5w-30 weight oil.
I have tried 10w-30 oil (M1, RP) and have found that the engines got noisier rather than quieter. Happened in both my Z and my 6.0 Silverado. I still run 5w-30 in both year-round.
