Hot Cam
Old Aug 27, 2006 | 02:07 AM
01BlackCamaroSS's Avatar
Default Hot Cam
Im about to pick up a ls1 hot cam for cheap and was wondering if it would be able to drive and actually get good numbers with the stock torque converter, i want to get a bigger cam for now until i update to heads and get a race tranny for now the hot cam would be fine just wondering if it would be ok with the stock tc
Old Aug 27, 2006 | 02:09 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It will "suffice". By that, I mean, you will be able to drive the car from point A to point B no problem. But You will be leaving power on the table mostly by running the stock converter.
Old Aug 27, 2006 | 09:45 AM
BigDaddyBry's Avatar
I did it for a few months. The only problem was the surging when coming to a stop. I thought it wasn't that big of a sacrifice, until I got a TC.
If you don't know the difference, then it will be a minor adjustment.
Old Aug 27, 2006 | 09:49 AM
Charlie@LsXperts's Avatar
im runnin a stock verter too..... a stall is a good mod but some people can do a cam cheap and just want to wait for a stall
Old Aug 27, 2006 | 11:22 AM
I dont want to sound stupid but what do you mean by surging when you come to a stop
Old Aug 27, 2006 | 11:32 AM
93ChevExt5.7's Avatar
Surging - at least to me is the feeling where the engine speeds up and slows down all by itself. It kinda feels like the vehicle is bucking a little, but its nothing big. Check this: https://ls1tech.com/forums/showthrea...=532533&page=2
Old Aug 28, 2006 | 04:17 AM
Billiumss's Avatar
I tuned a 2001 TA A4 with that cam with a stock converter and he put down around the 375HP range. The best he did at the track was 12.1 at 116mph, yes stock converter!
With the proper tune, it won't surge with that cam and stock converter.
Old Aug 28, 2006 | 07:44 AM
Do you guys think that it is a bad idea to buy a cam used that has 5k on it, im getting for 170 shipped
Old Aug 28, 2006 | 08:21 AM
Billiumss's Avatar
Cam should be fine unless it looks tore up, get pics.
You'll also need pushrods and springs. Get the LS6/Z06 springs from SDPC for around $53.00
Old Aug 28, 2006 | 03:54 PM
The car wants to go, so you have to mash the brake more to keep it from moving.
I would compare it to power braking at 1500-2000rpms, yet you are at idle (800rpms).
