Micropolish and Nitrated?
The stocker will handle what you can throw at it, as a matter of fact, I've yet to see a thread about (my crank failed under boost) at the levels you are talking about.
1- I would gather parts, but I would get a professional LSx shop handle the built. that IMO is more crucial because you are going to want the most stable and reliable shortblock built for this type of power.
2- You are looking at at least 15000 buckaroos in parts alone so managing your $$ is crucial.
Really worth the money. My last 600rwhp Supra motor cost me $550 to do.
One word of advice though, make sure you assemble the motor to final specs, before teardown to be cryo'd.
Otherwise good luch grinding or filing anything.
(as a matter of fact, I have some parts in my 10 bolt rear that are cryogenicaly treated along with micronite treated gears) who needs 12 bolts anyways
Otherwise good luch grinding or filing anything."
so your saying put the engine together then pull it apart to have it Cryo'd?
Also you need a special hone on the cylinders otherwise no way to seat the rings (which are cryo'd too)
