looking for about 500hp
Old Sep 10, 2006 | 10:30 AM
408Maro's Avatar
Default looking for about 500hp
hey guys whats going on i got me a 02 z 6speed and looking to got around 500hp or round that area. not looking to go any power adders like charged or juiced,what do u guys suggest tht not to pricey? now i already know this is going to cost as it is lol but i am looking to keep the stock block thanks guys
Old Sep 10, 2006 | 10:34 AM
mcamp001's Avatar
heads and cam will get you there pretty easy
Old Sep 10, 2006 | 10:36 AM
1 last 1's Avatar
Just put the motor that your name refers to, and your there.
Old Sep 10, 2006 | 10:51 AM
408Maro's Avatar
thats what i was thinking but how do i know what size cam and all that? is the hot cam good or is that to small? and yea i wish i could afford the 408 one day
Old Sep 10, 2006 | 11:08 AM
Slowhawk's Avatar
LS1Tech Sponsor
Cheap and 500hp doesn't mix.
Old Sep 10, 2006 | 11:16 AM
slow trap's Avatar
+ 1 . are you looking for 500 fwhp or 500 rwhp ? i'd say something like a 228 -232 cam,lts,ory,ud pulley, and a tune will put you in the 385-400 rw range.you will probably have to get heads to get in the 425 + range to be at around 500 fwhp.
Old Sep 10, 2006 | 11:19 AM
just1news6's Avatar
Actually Check out the Dynometer section Mike and Ron at vengeance racing have a trick flow headed with full boltons that is still in initial tuning that laid down 488rwhp and wil most likely put down 500 after they get a new fuel pump and break it in. And thats only a 346
Old Sep 10, 2006 | 12:19 PM
408Maro's Avatar
hmm thanks so far guys at the moment i have lts with x pipe dumped before the axle i guess in the near future i will be getting the cam and i want a tune but i want to see about getting one of those laptop programs what do u guys think is the best diy tune program to get?thanks guys
Old Sep 10, 2006 | 03:41 PM
spazzyfry123's Avatar
Hp Tuners
Old Sep 10, 2006 | 03:48 PM
SS LS1's Avatar
EFI Live
Old Sep 10, 2006 | 04:31 PM
erikthegoalie's Avatar
+1 for EFI live, great program
Old Sep 10, 2006 | 06:03 PM
zspot98's Avatar
Does it have forged internals. I can't see you getting to 500 IMO, not even w/ a radical H/C combo?
Old Sep 10, 2006 | 06:26 PM
just1news6's Avatar
yeah ill send you the link to it the heads have been totally revised reengineered by trick flow
https://ls1tech.com/forums/dynamometer-results-comparisons/572505-vengeance-racing-trickflow-do-again-488rwhp-430rwtq-346-street-car.html
Old Sep 10, 2006 | 07:08 PM
GuitsBoy's Avatar
Like the others said, 500 engine HP is possible out of a fairly stout heads and cam package. 500 rear wheel HP is safely beyond the reach of all but the most radical, advanced and expensive setups. You'd need something very agressive, with some exotic boltons to get there, and once you do, itll drive like crap on the street. And if that wernt bad enough, your stock internals are in danger, especially if youre spinning to the moon to make all that power. Shoot for the 425-450 range H+C setup, and you can still tell the layperson you have 500 HP.
Old Sep 10, 2006 | 07:17 PM
dalejr8ls1's Avatar
You have a lot of searching and reading to do. Get a feel for how different combo's are working for people. Most stock block heads/cam/intake mods will be in the 430-480 range. If you want a solid 500+ hp I would go with a 402 shortblock and decent set of heads w/ not too big of a cam. Of couse some people are putting way more than 500 with agressive 402's and 408's. Just start searching.
Old Sep 11, 2006 | 09:25 AM
pewter 01 SS's Avatar
+1.. like everyone else said its not cheap getting 500+ rwhp. you have to get a good combo of parts if not all the money will be down the drain.. seen it happen a lot in here so do your serching but for sure your going to need good heads, cam and intake. good luck
Old Sep 11, 2006 | 10:09 AM
300bhp/ton's Avatar
I don't know your definition of HP but I think you are pretty mistaken. A genuine 500bhp motor (rated in the languge we know and compare to other manufacturer vehicles means 'bhp SAE Net'). You would need your car to be making a solid 440+rwhp SAE corrected with sensible graph smoothing on a MUSTANG dyno. On a Dynojet you would need somewhere around 470rwhp SAE corrected to really have a legitimate claim to a 500bhp motor.
There are several guys with such a setup, but not that many on a 346ci and all have required h/c and full bolt ons. And the cam will have to be closer to wild than mild.
As for 500rwhp, well I've yet to see on from a Mustang dyno or even one corrected SAE with decent graph smoothing. I don't doubt the LS1 is capable of such power with stock displacment but it is pretty much race track territory only.
Old Sep 11, 2006 | 10:14 AM
300bhp/ton's Avatar
Cheap option:
TSP MS4 and Stage 1 PRC heads (or Terminator heads, but more $$$ and require flycutting).
Ported stock TB
lid
Pacesetter LT's
TSP Rumbler X duals
It won't be 500bhp, but it will be pretty mean. Other bolt ons like pulleys and CAI may also help, or a wilder cam, but flycutting def needed.
You'll probably also need to think of oil pump, fuel injectors, timing chain, head studs and a tune. If you plan on making it last and achieve it's intended HP level.
BTW - stock suspensin & chassis will be pretty useless with that much HP not too mention the rear end will probably blow also.
Old Sep 11, 2006 | 10:50 AM
black01_WS6's Avatar
save about 10k+ to get yourself there. 500hp on a 346 is harder than most people think w/o using FI.
Old Sep 11, 2006 | 11:13 AM
WS6TransAm01's Avatar
CARTEK Racing
Maybe Flywheel Horce Power.
How many stock bottom-end Heads+Cam cars can you name? LOL
It IS posible with a Heads+Cam and the usual bolt ons, but its not cheap or easy.
I am currently [that I know off] the highest HP hydrolic roller H/C stock bottom end LS1 around at 507.9RWHP and 433.6RWTQ. Put down on a chasis dyno through 4.56 gears in a 12-bolt.
But I am one of only a few. I can only name 2 other cars that have hit 500+ with Heads+Cam on a stock shortblock
One was another CARTEK Corvette about 3 years ago [502RWHP] The other is a TTP car. I think LG claimed close to 550 but that was not a stock shortblock.
