Long rod 6L for boost?
Old Sep 10, 2006 | 12:20 PM
kbracing96's Avatar
Default Long rod 6L for boost?
I'm putting together a budget build 6L for my DD STS truck. I generally run 7-10psi of boost on this truck. I had someone suggest that I make a long rod motor which would help it with low end torque (which is why I'm going from the 4.8 to the 6)and more reliable higher rpm capability.
The plan is to use stock 4.8 rods (6.275") with off the self 402/408 forged pistons on the stock 6L crank and block. This combination would put the piston "in the hole" about .039. With the 76cc 317 heads ans a flat top 2cc piston and .040 head gaskets, that would give me just over 9 to 1 if I didn't deck the block. What do you guys think.
Old Sep 10, 2006 | 01:13 PM
GrahamHill's Avatar
I believe that rod is a powdered metal rod that wouldnt hold at ~550hp but I may be wrong.
A long rod, forged, would be good though!
Old Sep 10, 2006 | 02:09 PM
stevieturbo's Avatar
That would require a custom made set of pistons, becasue nobody is gona make the piston you want, with the 0.944 pin that factory rods use.
Will it be worth the hassle ? over a normal length 6.125" rod, which isnt exactly short by any means.
Old Sep 10, 2006 | 03:02 PM
KAOS's Avatar
also 6l heads are 72 cc's not 76's just figured i would throw that in there
Old Sep 10, 2006 | 11:43 PM
kbracing96's Avatar
What size pins do off the shelf 408 pistons use?
Old Sep 10, 2006 | 11:48 PM
kbracing96's Avatar
This motor is being built for truck duty, not track duty BTW, I'm looking to make the most power under the curve as possible, not necessarily peak power. I want a pulling motor, 2000-5500rpm. I'd rather run more boost with less timing and rpm to make power where I need it.
Old Sep 11, 2006 | 12:22 AM
red90cobra's Avatar
oof the shelf is usually .927
Old Sep 11, 2006 | 01:26 AM
TurboGibbs's Avatar
All of the off the shelf 408 pistons i've seen are the .927" pin for the 6.125 rod. The 6.125 rod is a gen 1 small block chevy aftermarket. All the factory gen3 engines use the .945 wrist pin. I have never seen an aftermarket gen3 rod btw.
For years all I have ever read and heard is a shorter rod will increase low end tq. The piston accelerates off of TDC quicker due to the relation of the angle of the rod with the crank. If you aren't building a competition purpose built engine the only real advantages i'd see with going with a longer rod is to reduce cyl wall side load. The sbc 350 (3.48 stroke, 5.7" rod) has a stroke to rod ratio of 1.637 the 6.0 (3.622 stroke, 6.098 rod) has a rod ratio of 1.68. The 6.0, with stock rods, has a better rod to crank angle than the sbc 350 does and it has 40 years of proven use of being a work horse and a great race engine.
Old Sep 11, 2006 | 11:29 AM
red90cobra's Avatar
what's the cranks size for the 4.8?
Old Sep 11, 2006 | 12:32 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
3.27 stroke in the 4.8
Old Sep 11, 2006 | 02:19 PM
vanillagorilla's Avatar
From what I understand, with a longer rod engine, the piston speed is reduced significantly. When you reduce piston speed, it obviously doesn't accellerate as much which reduces the force on the rod and rod bolts. This would allow greater rpm capability. As stated above, side loading is reduced which will help the engine live longer. Having the piston dwell at TDC longer helps increase cylinder pressure too.
My experiences have shown that a 355 with a 6.0" rod will make more power/tq than an otherwise identical 355 with a 5.7".
So how much more would a set of pistons cost with a different pin size? I know the more popular piston manufacturers make pistons for use with stock length rods. So they have the tooling and programs for the 4.8's pin size.
Old Sep 11, 2006 | 02:59 PM
Ryan K's Avatar
Pathological Modifier
Then you must be Blind or Deaf...
http://www.thunderracing.com/catalog...vid=3&pcid=120
Ryan K.
Old Sep 11, 2006 | 03:45 PM
Forced370GTO's Avatar
[QUOTE=vanillagorilla]From what I understand, with a longer rod engine, the piston speed is reduced significantly. When you reduce piston speed, it obviously doesn't accellerate as much which reduces the force on the rod and rod bolts. This would allow greater rpm capability. As stated above, side loading is reduced which will help the engine live longer. Having the piston dwell at TDC longer helps increase cylinder pressure too.
QUOTE]
no offense but thats wrong, the movement of the piston is directly related to the stroke of the crank. the rod is only a medium between the stroke of the crank and the piston. regardless of rod size, the piston will always move the same distance over the same time (velocity) at any given rpm. your philosophy would allow the displacement to be changed simply because you changed the length of the rod.
Old Sep 11, 2006 | 06:38 PM
not quite true.
Overall distance/time may be the same, but pistons velocitys at ( or acceleration if you want ) at and around TDC and BDC will be massively reduced with a longer rod.
Piston velocity doesnt just measure the average over the entire stroke, as it changes throughout its travel, and those changes are dictated obviously by rpm, but also by rod length.
Old Sep 11, 2006 | 11:56 PM
TurboGibbs's Avatar
Ryan K.
I stand corrected. Manley makes 1 but it is just the gen SBC rod with the wrist pin honed out to .945". You can take a rod bearing out of a 1969 350ci sbc and put it in a 2002 346ci LS1 gen3 (6.098 rod). The gen 3 uses the same brg. Since thus it is cheaper to machine pistons to fit the sbc rods rather than forge an entirely new rod. Every other rod is a gen1 rod with the word LS1 in the description that Thunder Racing put in there. Here is a link to Lunati, notice the LAE1 part # (sorry for the not sponsor link but it is just for info).
Lunati LAE1
not quite true.
Thank you.
When I said a shorter rod is supposed to impove low end tq I am refering to off-idle primarily.
Old Sep 13, 2006 | 09:49 AM
I emailed JE/SRP, so we'll see what they come back with. They're a sister company of ours, so maybe I can score a good deal on some pistons. I'll keep you all posted.
Old Sep 13, 2006 | 12:08 PM
2001CamaroGuy's Avatar
When I built my 388 big bore, I used a stock crank, off the shelf SBC 6.300" forged rods, and 4.130" bore forged pistons (that were designed to go with a 4" stroke crank/6.125" rod. It worked out to a perfect 0 deck height setup.
Positives are that the acceleration of the piston at TDC/BDC are slower, the higher pin/shorter pistons are lighter, and the overall system is smoother turning. It works REALLY well at high RPM (7000+RPM)
Downsides are because the acceleration at TDC/BDC are slower, low RPM "intake signal" is even worse than it otherwise would be. The piston spends less time at max velocity so there is less pressure differential to pull intake charges in. Now I have to keep in mind that I have 2.08/1.60 valve heads with big ports and a 244/249 112LSA solid cam so the engine would be "slugish" down low no matter what. "HOW MUCH" is the "engine" I'm not sure.
IF I were building this engine again, I would have offset ground the crank to build a 396 and installed a small bearing SBC 6.250" rod (also an off the shelf rod), not because the rod is "too long" but because the smaller bearing would free up a bit more power and work better at higher speeds. The reason I would offset grind vs. just turning the crank down is at that point, CIs are free.
Old Sep 19, 2006 | 05:08 PM
Check out this thread. I don't know if the engine was ever built but...
https://ls1tech.com/forums/showthrea...t=6.0+long+rod
