LPE GT2-4,- what springs?
I have a GT2-4 on it's way from LPE. They told me that my stock LS6 springs would work fine with this cam. I know that they know much more than I do, but isn't .566 lift pushing the limits? My springs have all been checked and are still holding their new specs.
I think if you switch cams, then you should change the springs, just because the springs are a wear item. You might be able to get by with the stock springs, but the chances that you won't are higher than normal. Breaking a valve spring is potentially really expensive.
Originally Posted by NviouSS
what are the specs? there is no Gt2-4 listed on the lpe website.
Originally Posted by vettenuts
If you have the Z06 valves, listen to LPE's recommendation. The Z06 springs will work, I know someone running a similar setup with more duration with the Z06 springs, no problem at all.
It is not only a matter of lifts, you have to look at the seat pressure of the cam. LPE lobes are lazy by todays maket. LS6 will work.
However, if you have a few miles on them, I would toss in a new bunch.
I just got my GT2-3 off the UPS truck today....I spoke with them last week and they tell me that my LS6 springs will work great...(They even sell a kit that includes the GT2-3 and the LS6 springs) This cam has .571/.578 lift...
Ray
Ray
Originally Posted by madeouttaglass
The springs all measure 94+ lbs at 1.80" (That is what they are supposed to be new.) Not to be too much of a dumbass, but how often do you recommend they be changed? The car is not raced and rarely sees redline. I don't think that GM asks for them to ever be changed- even on the Z06.
