Got the car dynoed...low #'s??
With a different intake and injectors there's more power to be found in that combo for sure. It's too bad you didn't mill the heads before they went on cause you're losing some power right there.
Did you make a baseline run before the tune or before the heads/cam isntall? It would be interesting to see how much tune netted you hp wise...I really do think it's a conservative tune...You can get cars with bolt-ons only to put down those numbers.
Would milling them have made them not suitable for poor gasoline?
LS1's have knock retard so if it did start to knock due to a bad tank of gas the computer should compensate.
STOCK
295hp/305tq
pinging (bad gas & fouled plugs)
on a 4wd dynojet
isnt so bad after all???
what gear was the car in during dyno sessions? what rpm did you take it to? i've read a lot of threads where 273 geared cars couldn't run out 3rd gear all the way or had to make a pull in 2nd gear just to reach the rev limiter, ultimately skewing the numbers.
confirm your a/f is good then take it to the track and see what it runs. dynos mean nothing, the tuner could've simply put in the wrong correction factors or something...who knows.
bottom line: GET A TIMESLIP.
Something is definetly holding your power down some. Maybe the tune, but like others have just mentioned, bigger intake/TB, and injectors.
