Different rings in an 01?
Old Oct 1, 2006 | 12:47 PM
BLKWS.6's Avatar
Default Different rings in an 01?
Someone said 01 LS1's burn the most oil due to rings and that 02's got different rings...whats the difference?
Old Oct 1, 2006 | 02:21 PM
vettenuts's Avatar
02's got the Napier rings with slightly more pressure as well. On the LS6, they started immediately in 02 production, the LS1 got them a couple of weeks later so a very early 02 will have the earlier rings as well. The new pistons came in March of 01 so all 02 production and later 01 production got the new pistons.
Old Oct 1, 2006 | 02:43 PM
BLKWS.6's Avatar
Is this really something that matters, or just "different but =" Would I be better off with an 02 than an 01?
Old Oct 1, 2006 | 04:12 PM
vettenuts's Avatar
Not sure if you already own the car, but if you are shopping for one (I see your Mustang photo) than I would opt for an 02 if you can find one. Here is a link to the explanation on the rings writen by Hib.
Hib's Article
Old Oct 1, 2006 | 04:53 PM
BLKWS.6's Avatar
I am shopping. THANKS for the link!
Old Oct 1, 2006 | 06:34 PM
BLKWS.6's Avatar
I just got off the phone with my friend, who has a 01 WS6 made in 7/01 She told me according to teh GM dealership starting in 7/01 production they used the new ring package with the Napier 13# oil ring. She also has had her engine torn down and disassembled (planning TT setup) and visually verified that her car DID HAVE the napier rings in it. Whats up? Anyone have anything to contradict this? both her and the GM dealership she delt with verified that the new rings were used in ALL LS1's! starting in the 7th month of 01.
Old Oct 1, 2006 | 06:36 PM
SHINER's Avatar
what do 99's have??
Old Oct 1, 2006 | 06:43 PM
BLKWS.6's Avatar
1.5mm/1.5mm/3mm with a 9# low tension oil ring and a conventional scraper face. (IIRC, please correct me if I am wrong). <1999 LS1 ring package from GM
Old Oct 1, 2006 | 06:59 PM
SHINER's Avatar
So are they any good? ANy different from 01?
Old Oct 1, 2006 | 07:18 PM
vettenuts's Avatar
July 01 would be the start of 02 Corvette production so the date is just about correct. Not sure what the change over is on the f-body, but the engines all came out of the same plant. Production change over for the Corvette is in June.
Old Oct 1, 2006 | 07:43 PM
BLKWS.6's Avatar
Sorry to be a dense one, but the 02 production will still be an 01 model? confused* It will be an 01 Z28 but have the 02 stuff in it, starting 07/01 ??
Old Oct 1, 2006 | 07:59 PM
SHINER's Avatar
ya and please explain to me wat u said about 99 rings, lol.
Old Oct 1, 2006 | 08:15 PM
BLKWS.6's Avatar
They are the same except for the oil ring which is 13# tension and has a different scraper profile called a "Napier" face or profile. The 99 is conventional and has 9# tension.
Old Oct 2, 2006 | 05:11 AM
vettenuts's Avatar
The ring change was done per the Corvette production schedule. The Corvette model year change is actually in late June of the year prior to the model year, so the 02 production actually started in late June/early July of 01. Thus, the new rings went into the motor in July of 01. Now if the f-body production change is for example in September, than the 01 f-bodies produced in July of 01 as 01 model year cars probably got the new rings since the engines all come from the same plant.
Do you know in what month the f-body model year production changes?
Old Oct 2, 2006 | 09:45 AM
BLKWS.6's Avatar
Ls1 F-bods according to an article I read "got the rings a few weeks after the Vettes' " And that would make it 7/01 IIRC. I understood YM02 to be ONLY 2002 VIN'ed cars. Apparently, and thankfully, I was wrong and it includes late model 01's and I can find out if it has it or not by looking at the door sticker. If you look at my poll you would be stunned at the results. It seems the ring package is doing its job all but perfectly. (all of 02 had it and half of 01' had it...keep that in mind when youview the results...)https://ls1tech.com/forums/showthrea...=585109&page=1
Old Oct 6, 2006 | 12:05 AM
KENS_SS_4's Avatar
Because the F-bodies were ending production. The change over to 02's production started in May of 01.
Old Oct 6, 2006 | 04:41 AM
vettenuts's Avatar
On your poll, make sure those responding also have the stock PCV system, even though the PCV system allows oil through it when you mess with it the oil consumption seems to get a lot worse.
Old Oct 6, 2006 | 04:46 AM
SOM02WS6's Avatar
If you knew the answer why ask the question and the tell people they are wrong and give them **** when they answer your question?
