4.030 heads on a stock cube engine?
what's too big about them? we know nothing about the heads other than they are supposedly for a 4.030 bore. 6.0L heads are on a motor that is a 4.00 bore. you see many people putting them on a 346 LS1.
C-Dub you are going to lose power, especially over the Darts! Those stage 3 heads are meant for the larger bore, when running them on the 3.910 you will shroud the combustion chamber and actually should lose compression.
