Ms4 or V.3
Old Oct 24, 2006 | 02:34 PM
  #61
stangkiller2005's Avatar
Originally Posted by Oh4GTO
^^^ However I have LS5 heads and the vavles on those are longer than an LS1 head so I can get away with 7.400 for now (since I have them already).
so when did they come out with ls5 heads?
haha..jp..jp
Old Oct 24, 2006 | 02:44 PM
  #62
DogNutz's Avatar
haha..jp..jp
SSSSSHHHHHHHHHHHHHH!! Top secret! Release in 2010! Very similar to the ZR1 heads but for LSx series engines!
Old Oct 24, 2006 | 03:04 PM
  #63
Oh4GTO's Avatar
I meant LS6.......you guys are funny.
Old Oct 24, 2006 | 09:21 PM
  #64
rickyracer25's Avatar
ok fusk the lifters, and the winner is the MS4 with an lsa of 110 PRC Spring Kit & Pushrod Package, Rollmaster Double-Roller Adjustable Timing Set, ported ls6 oil pump, Cam gasket and bolt kit. Total is $948.48, and another $350 or more for the tune.
So my qustion now is what should I degree the cam to? I think it should be 110+3 but I'm not sure.
Old Oct 24, 2006 | 11:57 PM
  #65
Oh4GTO's Avatar
If your going to advance it I dont know about PTV clearance.
Old Oct 25, 2006 | 12:30 AM
  #66
cws T/A's Avatar
'' We offer MS4 camshafts on a 110 , but for p/v issues it's only available to customers with cut pistons. '' Jason Texas-Speed
https://ls1tech.com/forums/generation-iii-internal-engine/527160-feedback-patrick-g-s-torquer-cam.html
Post # 88
Old Oct 25, 2006 | 01:14 AM
  #67
Thanks, "Old Man" sure would have sucked to get all that installed and find out that I have a PTV issue .(HAHA that would have been great having to take the heads off anyway to solve that problem and not have the lifters to change out while the heads was off.) Looks like this youngin still has some things to learn. Anywho what would be an acceptable lsa and degree for the MS4?
Old Oct 25, 2006 | 07:05 AM
  #68
Wyckedcamaro's Avatar
111 i have mine.
but my pistons ARE cut.
Old Oct 25, 2006 | 09:10 AM
  #69
but you also have heads in your set-up, right? I really remember reading in a post not long ago that someone from TSP said that the ms4 didn't require fly cutting on the stock heads.
Old Oct 25, 2006 | 09:15 AM
  #70
eric01ss's Avatar
ill be getting the MS3 for my car and it a proven performer look at what terminator made with heads and 90/90 setup 490 to the wheels
Old Oct 25, 2006 | 11:59 AM
  #71
yeah I have tea stage 3 heads.
So that takes care of that lol.
yeah ms4 cam is SUPPOSED TO WORK WELL WITH STOCK HEADS.
Supposed to.
Old Oct 25, 2006 | 01:15 PM
  #72
Killer_Bluebird's Avatar
I have the MS4 on a 111 lsa. I installed it dot to dot on stock heads. No problems with valve clearance. I do have to get new injectors as I'm maxing out mine and I don't even have headers yet. So if you don't have 42# injectors in your list, it will probably be a good idea. Right now my Stock Manifolds are severely limiting the cam. But since I'm planning going with 1 7/8s over the winter/early next year I'm not concerned.
Old Oct 25, 2006 | 02:18 PM
  #73
Who tuned it? What's the duty cycle that you running on the injectors? The 13.01 in you r sig is that after the Ms4. How are the streetmanners?
and and and and? sorry for all the questions
Old Oct 25, 2006 | 04:09 PM
  #74
I got the tune done at GMR Speed but we are not done yet. On 1st gear at 6,592 rpm I'm at 99% injector duty cycles, on 2nd gear at 6,428 rpms I have 104% injector duty cycles. Without a tune it wasn't not drivable, I did not unkooked the battery so I'm sure that didn't help. I didn't want to drill the tb so I use hp tuners and got it pretty good but I think I'm going to use the set idle screw in the tb trick to see if I can make it better. I still have a bit of surging and bucking at low rpms. So it has taken a bit to get use to it and adjust my driving style to the car, I've driven it to work a few times and in rush hour is fun, I get a lot of weird looks and thumbs up.
The times in sig are without the cam on street tires and 2.x 60'.
Old Oct 25, 2006 | 08:08 PM
  #75
Stang-Slayer's Avatar
I love my torquer v2 !!!!
Old Oct 26, 2006 | 12:56 AM
  #76
Yeah I will drill the tb and reset the pcm. The only thing is that I can't afford all this (budget is already way more then what I planned, good thing I had a little extra) and a tow down to lubbock. Do you think that the car can make it an hour and a half at highway speeds? varying the Rpms. the drive will be done two or three days after the install so the springs are broken in for the tune.
I will have them watch the injectors, if it is to crazy I will just have to baby it for a while. Only have 2500 to play with and the clutch isn't being nice.
Old Oct 26, 2006 | 10:43 AM
  #77
Brian @ Texas Speed & Performance's Avatar
LS1Tech Premium Sponsor
The MS4 and T3 are both good camshafts but are two different setups. The MS4 is going to make more top-end power and requires the right setup to drive it on a daily basis. I DD the MS3 for a couple of years and loved it. It will limit the head choice down the road unless you want to flycut the pistons. The T3 will have more mid-range but not the peak power of the MS4 and will be a better DD cam for alot people looking for this type of cam(I DD my setup). It will provide a wider variety of head choices down the road if that's what your planning.
Brian
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
www.texas-speed.com
(806) 866-0734
Old Oct 26, 2006 | 09:05 PM
  #78
Originally Posted by Brian @ Texas Speed & Performance
The MS4 is going to make more top-end power and requires the right setup to drive it on a daily basis. Brian
What is the right set-up for the MS4?
Old Oct 26, 2006 | 09:15 PM
  #79
N4cer's Avatar
Just flycut. Get it over with. You'll take full advantage of the cam, and not waste your money. Both of those cams would really benefit from the increased compression that you could run if you plan to flycut anyway.
Old Oct 26, 2006 | 09:53 PM
  #80
K I now know for sure that you don't have to flycut for the cam to fit on stock heads. I was actually talking about pushrod lengths, shims on the springs, whatever else.
