1st gear at 65
Old Oct 22, 2006 | 05:12 PM
WhosNXT's Avatar
Default 1st gear at 65
Alright guys I did it now what can I expect. I was In town this morning and a fox body pulled next to me and started to pace me. So we ended up running from about a 40 dig. When I went for third I hit first. When I droped the clucht and the violent shutter unleashed I quickly pressed in and went to neutral. Drove it home with out any noises or problems. Can I expect anything to break now?
Old Oct 22, 2006 | 06:23 PM
Insanekamel's Avatar
i kinda did that at the track a while back.... with in the next week i was leaking oil out from behind the balancer and had to pull it off and put it back on... it was close to shooting off...
Old Oct 22, 2006 | 06:42 PM
DuronClocker's Avatar
I went into 2nd instead of 4th at the top of 3rd and slammed some valves into some pistons. Obviously bent the valves and drove it like that (VERY rough running) for a little over a month before it developed a main bearing knock.
Old Oct 22, 2006 | 06:49 PM
Asmodeus's Avatar
putting it in first at 40mph isn't too bad. Worst case probably bent pushrods but it doesn't sound like you did. I will put it into 2nd at 60, and third at 90. You probably didn't even get to 7000 assuming you have stock 3.42's
JimMueller's Avatar
Stock heads and/or valvetrain? If you've got stock pushrods and you're comfortable with it, I'd pull them and confirm they're still straight. You should know if you damaged a piston by it's manners.
Old Oct 22, 2006 | 06:56 PM
jermzz's Avatar
You'd know if there was something wrong with the motor right away, however, depending on how hard you hit into gear, be prepaired to replace your rear end in the not so distant future.
Old Oct 23, 2006 | 03:31 PM
WhosNXT's Avatar
Alright Thanks guys! Yeah Im still runing the stock gears so if they break it wont be such a bad thing, Ive been waiting for it so I could replace it with a nice rear end. The car drove fine today without engine noise. But I did notice a pop through the exhaust when feathering the throtle at take off. But Im thinking thats either a plug or maby a coil pack.
Old Oct 23, 2006 | 04:02 PM
ArcticZ28's Avatar
Or that could be a slightly bent exhaust valve that isn't properly closing all the way and leaking fuel into the exhaust causing the pop.
Old Oct 23, 2006 | 04:06 PM
Ice Knight's Avatar
Kinda off topic....but I've read that 3.42's m6 f bodies can go roughly 55 in 1st, 75 in 2nd, 105 in third...and I forget the rest...also in video game that how fast they go....any truth to my question?
Old Oct 23, 2006 | 04:11 PM
blk99camaro's Avatar
Sounds about right to me, I know I trap 109mph at the track in 3rd without bouncing the limiter, but my revlimiter is at 6400, stock is 6200 so your probably about on...
Jon
Old Oct 23, 2006 | 04:45 PM
00454sscamaro's Avatar
i can hit 60 in first if i wind it out(before heads cam and mail tune) i havent really payed attention to 2 and third as much more focoused on the road by then. but sounds about right.
Old Oct 23, 2006 | 05:38 PM
hammertime's Avatar
If I read the original post right, he raced from a 40mph roll, and when he went to shift third, he got it in first instead. Putting it in 1st at 75mph would be bad.
I did the 2-3-2 shift once, and it broke the trans mount, but that was all. If you seem to get the pop in the exhaust all the time, you could run a compression and leakdown test to know if there was any damage. Just make sure you do it with the engine as warm as possible (for a better valve seal).
Old Oct 23, 2006 | 06:00 PM
erikthegoalie's Avatar
i did that once....everything was fine...i think everyone is granted a
"get out of jail free" card once or twice on this...but thats it..
erik
Old Oct 23, 2006 | 06:07 PM
GuitsBoy's Avatar
most common issue after a mechanical overrev is a bent pushrod, which are easily replaced. A few unluck people have bent valves though, so there are no guarantees.
Old Oct 23, 2006 | 06:15 PM
rocketman442's Avatar
I can spin it up to close to 70 mph in 1st with stock gears and tires with a h/c car you shouldnt have hurt much at 40 mph lol
Old Oct 23, 2006 | 06:17 PM
GuitsBoy's Avatar
The title says 65 mph w/ first gear. That would put him deep into the 7000+ range.
Old Oct 23, 2006 | 06:24 PM
dnm12's Avatar
4.11's near 6000 RPM in 4th gear at 112
Old Oct 23, 2006 | 06:53 PM
oops didnt read the title just the post, I need another beer.
Old Oct 23, 2006 | 07:10 PM
WhosNXT's Avatar
The Poping is not constant. It only happened 2 to 3 times in the 2 days after bad shift. Thas what was making me think it was plug, wire,coil pack, instead of a vavle.
Old Oct 23, 2006 | 07:12 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You might have a bent pushrod though. It can be a number of things, or just all in your head as well.
