Trick Flow Heads
Old Oct 22, 2006 | 09:01 PM
nd4spd22's Avatar
Default Trick Flow Heads
Has anyone heard or tried to put these Trick Flow Heads on their LS1?TFS-3060T001-C01 If So how much HP / Torque gain are there on a stock motor Thanks
Old Oct 22, 2006 | 09:20 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I just searched and found this information:
https://ls1tech.com/forums/showthrea...S-3060T001-C01
Old Oct 22, 2006 | 09:22 PM
Louie83's Avatar
The 215's are shaping up to be bad *** heads for a 346. There haven't been tons of results yet, but the flow numbers and dynos have been very promising.
Old Oct 23, 2006 | 12:02 AM
cws T/A's Avatar
noitamrofni siht dnuof dna dehcraes tusj I
https://ls1tech.com/forums/showthrea...ight=tfs+heads
Old Oct 23, 2006 | 08:39 AM
JNorris's Avatar
Moderator
I have had great results. See links to posts below:
https://ls1tech.com/forums/showthrea...ighlight=trick
Old Oct 23, 2006 | 08:49 AM
TXZ28LS1's Avatar
yeah, i hear those heads are kick a$$. dont know how much they cost though. there was another post, where i think somebody posted flow numbers vs. the afr's. and i think it outperformed it.. cant rememeber. but we all know how good of a product afr's are.
Old Oct 23, 2006 | 08:56 AM
Hardtop's Avatar
Can you run stock rockers with these heads, or do they have to be aftermarket?
Bruce
Old Oct 23, 2006 | 11:41 AM
exSSer's Avatar
They require roller rockers.
Old Oct 23, 2006 | 12:47 PM
Hardtop's Avatar
There hasn't been much said about this. Did you go with rollers on your original install, or did you add them later? Why won't the stock rockers work? This isn't a bash on TF or TEA, I ran TEA heads in the past with great results, and would probably go with Trick Flows if I bought heads. I would be running essentialy the same cam as you are, and stock rockers are fine with most other heads with that cam.
Bruce
Old Oct 23, 2006 | 06:54 PM
Firehawk441's Avatar
Out of the box they require rollers. If I'm not mistaken, TEA can machine the heads to accept stock rockers.
Old Oct 23, 2006 | 06:58 PM
jlrz28's Avatar
10 Second Fun Car
If their as good as all the other products should be a nice addition to any motor!
Old Oct 23, 2006 | 07:36 PM
slimcracka's Avatar
ive herd about valves breaking but i think they "fixed the dlitch" lol.
Old Oct 23, 2006 | 07:39 PM
SSpdDmon's Avatar
They were in the latest Summit catalog if you were looking for a price.
Old Oct 23, 2006 | 09:44 PM
mcamp001's Avatar
don't use stock rockers with these, I am having an issue, but won't disclose details until it's worked out with TFS
Old Oct 23, 2006 | 10:57 PM
rmitchell242's Avatar
i had the #3 exhaust valve wear down because of running stock rockers on my trick flows 3 weeks ago
trick flow overnighted me rollers no charge overnighted my heads back to them (ohio from california 350$ each way) fixed them while they were moving shops. overnighed them back to me and now they are on the car and running great!
from my experience you will have no problem getting this resolved
Old Oct 23, 2006 | 11:18 PM
Tecknique2006's Avatar
What company offers a set of compatible roller rockers? I tried Jesel's website but they only have Ford applications listed for Trickflow.
Old Oct 24, 2006 | 03:59 PM
Harland Sharps. You can buy them from there retailers for $389.00.
Old Oct 24, 2006 | 04:05 PM
hotrodrx7's Avatar
I have the Jesel Sportsman rockers on my TrickFlow heads. Not many miles on them yet but they seem to be doing OK.
Old Oct 25, 2006 | 08:39 AM
getusum's Avatar
Look at my sig...I'm running the jesel ss series and there great, and I pull at 7300
