MS3 in stock A4?
so it`s a must if I`m racing from a stop and want good times and runs and if I`m mostly racing from a role with 3.7`s I should be fine
my concerns was the 40-50 mph cruising with a higher stall and what I collected from reading about transmissions and higher stall on low rpm`s street use is the heat it produces and that say a 3500 stall should be 3500 or +3500 rpm when cruising and driving for a long time (again this is what I understood and I`m a no expert correct me if I`m wrong).
thanks again.
BTW dont always believe what you read unless you have experienced it yourself! i have over 50 runs on my tranny with this cam and over 100 runs total!
says his tranny didnt shift and it bounced it twice...he may have a higher mile tranny, also his is a 98 like mine and according the some posts in that thread the 98 computers are a PITA to tune. i have 80k on my tranny hence the reason i was worried.
basically the converter is a little looser, so you will have to give it slightly more gas from a stop and raise the rpms higher to get it moving. But it will only flash to the stall speed unless you give it a good amount of gas; say more than half throttle or so. once you get moving to say about 40-45mph the converter should lock up and the rpms will drop down to alot. People with converters only lose mpg in the city, for highway its almost the exact same. search around in the A4 section theres a bunch of videos of how these converters act on the street. one guy has a 4000k and at like 30mph hes at 1800. Oh and if your worried about it heating up get a tranny cooler. theyre like 60 bucks and will keep your tranny cool even with a big stall.
I wouldnt go as far to say from a roll youll be good. you still might be low in the rpm even from a roll, im not sure. go take your car for a spin and floor it from the roll point you plan on racing from and see where the rpm's are at when the tranny drops. remember the ms3 doesnt even start making good power until about 35-3600 and makes ideal power at 4000. thats why camscam is going with a 4000 stall to get the best results. Trust me, theres a reason people get a stall when they get a cam. im almost positive gears wont be enough to do it. also the car will suck to DD with no stall. at least thats what alot of people here say.
the way i look at it, theres no sense in getting a big mod like a cam and not going all the way with supporting mods. if your going to be spending $1000 on the cam, you might as well spend another $500-800 on a stall to really make the cam worth while. It seems like alot of money i know, but why half *** it? and as most know here, modding is not cheap lol.
Here is my plan. Im using the ms3 cam, which also peaks at 6800 rpm, and im going to be spraying a 150 as well. Ive done alot of research and am planning on setting my shift points to about 64-6500 with a 150. i also plan on having an extra 2 grand set aside in case if either my rear end or my tranny takes a dump. My car has 80k miles on it so i know one of them wont last long.
