Double springs on a stock cam
For the time being, try to find a set of slightly used LS6 springs and keep your stock p-rods, unless they are bent.
Does a double spring create too much stress for the stock internals? Or are y'all just concerned about the remaining spring life when the car finally gets a cam?
The key is running the "right" spring within cam requirement range.
So, is there anything wrong with this?:
LS6 springs and TSP 7.4 pushrods?
$50 $100
I would really like to get some titanium retainers, but i doubt that there is a double spring that would use the same retainer as an ls6. TSP sells the PRC retainers for $150 that fit behives.
Also, how reliable is the compressed air method when changing springs?
I thought it was a general rule that with a 98 and 99 you ditch the ls1 intake manifold and valvetrain, and go with an ls6 intake and a new pushrods and springs, second to putting the license plates on it and driving it home.
Jason
