Heads and Cam Question (potentially long...)
My first question, who would you all recommend having the heads worked by?
Also, on Cam specs, the 2 cams I have decided to make my final decision from are as follows:
Cam #1: Adv. Duration-265/271 w/ .515/.522 lift, 114 deg. Lobe Seperation factory computer no modifications necessary.
Cam #2: Adv Duration-269/273 w/ .525/.532 lift, 114 deg Lobe Seperation computer modification recommended.
Which of these two would be better for Stock displacement with a set of high flowing heads? I do not mind having the computer modified, but if the performance is not much different, would rather not.
Also, with the heads being worked, would an LS6 intake be worth the money to help get more air into the motor?
Thanks in advance,
Taco
types of springs, size of valves (anything larger than 2.02" Intake and 1.55" Exhaust) requires the stock valveseats to be machined out and replaced with larger diameter ones = alot more labor involved
<hr></blockquote>
Not to start a flame war, but it's common knowledge that on a 3.90 bore larger than 2.02 valves don't yeild you any power.
I have a guy in mind to do the porting for me, he does a lot of IHRA Pro Stock heads, and he does all of our in-house race engine heads. If he thinks he can get some good flow numbers out of them.
What are the best documented flow numbers for a set of LS1 heads?
What kind of numbers should I expect from them with a good port job, with stock-sized valves?
I had already thought about dual springs, and will probably end up going with them in the end anyway.
what about rocker arm ratio? Is there any performance to be had here, or reliability issues either?
Thanks again, and keep the info coming
Taco
Y'all talk to me about valves, sworl and tumble and all that, i know nothing about it, but would love to learn what they are and how to contol them.
Thanks again,
Taco
Many good head porters out there, its going to come down to opinion and availability. Just do some comparitive shopping and make sure you compare the hardware components and amount of work involved in them when checking out various shop's offerings. Look for brand names, types of springs, size of valves (anything larger than 2.02" Intake and 1.55" Exhaust) requires the stock valveseats to be machined out and replaced with larger diameter ones = alot more labor involved. Dual springs are a more expensive option, but worth it.
Yes, the LS6 intake is a worthwhile mod for a heads/cam setup. Typically 8-10 rwhp in most cases.
I've always had good luck with my MTI setups, which makes it too easy for me to support them. I've also not seen any packages come from that shop that made a customer unhappy with the performance gains. Just my own personal experience on the subject.
Tony
