Cam Install
Old Nov 13, 2001 | 10:20 PM
Ken98Z's Avatar
Default Cam Install
Any of you home installers use a degree wheel? Thanks Ken
Old Nov 13, 2001 | 10:22 PM
Ken98Z's Avatar
Default Re: Cam Install
Oh by the way. I love the site much faster. <img src="images/icons/smile.gif" border="0">
Old Nov 13, 2001 | 10:24 PM
flyin red TA's Avatar
How hard is it to degree a cam and does anyone know how much the tool costs?
I have the hammer in my closet...needs to be installed at a 108IC and I am bent on doing this myself.
Old Nov 13, 2001 | 10:28 PM
Ken98Z's Avatar
I did it myself and did not use a degree wheel. Is this that bad?
Old Nov 14, 2001 | 07:01 AM
y2kz28's Avatar
I didn't use one either. Just lined up the timing marks. The pin on the front of the cam controls degreeing. I believe the degreeing is ground into the cam, and you'd have to remove the pin to actually degree it in yourself.
Old Nov 14, 2001 | 07:40 AM
Ken98Z's Avatar
Thanks I was hoping that was the answer. <img src="images/icons/smile.gif" border="0">
Old Nov 14, 2001 | 07:54 AM
Y2K Camaro SS's Avatar
dot to dot
Old Nov 14, 2001 | 08:56 PM
MyLS1Hauls's Avatar
With a stock timing chain setup, you can not degree in a cam. Yes, you could skip a whole gear tooth, but thats a rather large change. The major problem with the stock chain is that is has lots of play in it, which alters valve timing. You'd need either a Comp Cams chain set or a Cloyes.
Old Nov 14, 2001 | 08:57 PM
BIGBOS's Avatar
Yea
Old Nov 14, 2001 | 09:14 PM
turbo's Avatar
So when I do mine do I have to do anything? Or do I just pull out the old cam and slide in the new one? Or do I have to line marks or something up???!?! <img src="images/icons/confused.gif" border="0">
I thought all you do was slide in the new one?
Casey
Old Nov 14, 2001 | 09:28 PM
StreetStalkerZ's Avatar
Turbo,when you slide the new cam into place and put the timing gear and chain on you have to line the crank gear dot up at 12 o'clock and line the cam gear up at 6 o'clock then slide the chain over,tighten it down to spec.,then turn the sprocket with your hand to make sure it free spins without digging into the cam plate.
Old Nov 14, 2001 | 09:39 PM
Kevin's Avatar
I didnt use a degree wheel either. Just dot to dot. You'll see the "dots" they are talking about when you have it apart.
Kevin
Old Nov 14, 2001 | 10:21 PM
turbo's Avatar
Thanks StreetStalkerZ. BTW do you have a TC or is it stock with your time in the sig?
Casey
Old Nov 14, 2001 | 10:30 PM
Ken98Z's Avatar
Do most people keep the stock chain when they do a cam install?
Old Nov 14, 2001 | 11:08 PM
Kevin's Avatar
I kept the stock chain but couldnt hurt to change the chain since youve already got it apart. I didnt cause I was already pushing the wallet limits on the heads/cam purchase.
Kevin
Old Nov 14, 2001 | 11:09 PM
Kevin's Avatar
Also it wouldnt be a bad idea to upgrade the oil pump while your at it to. They have been known to fail a few times.
Kevin
Old Nov 16, 2001 | 11:12 AM
JaSSon00's Avatar
dot to dot is no advance/retard, i dot to dotted mine.
Old Nov 17, 2001 | 12:01 AM
Bluestreak's Avatar
[quote]Originally posted by Ken98Z:
<strong>Do most people keep the stock chain when they do a cam install?</strong><hr></blockquote>
While you're in there, it's only another half hour (and $29.99) to change the chain. Drop the oil pan, unbolt the oil pickup (be very careful not to drop the bolts, I tied dental floss around them when they were lose) and remove the oil pump from the crank snout. Replace the chain (be very cogniscent of the placement of the timing marks' position). Replace the oil pump, torque down the oil pan (I suspect you could reuse the oil pan gasket, as mine was in pristine shape, but I took the time to replace the gasket - it took all out of 30-seconds with a die grinder and a soft abrasive pad to clean the old gasket off the pan) and you've replaced the timing chain and bought yourself another 30,000 to 50,000 miles that you don't have to worry about that item. It took another 30 minutes to do (that was taking my time) and you may as well do it while you're so close to it.
