Thinking about a cam, cam only guys give input
Old Nov 8, 2006 | 01:49 AM
Cchris1109's Avatar
Default Thinking about a cam, cam only guys give input
Ok so I have some extra money and I want to do a cam.
Curious on the different set ups people have, what they put down and avg mpg.
My combo right now is: Longtubes, x pipe with magnaflow, ported TB, lid, free mods, and a 3400 stall with 2.2 STR.
Plans: LS6 intake
Right now: 340 whp
My goal is 400 whp and call it a day.
So my question is, what different set ups have you guys done and what gains have you noticed, change in drivability and MPG. thanks!
__________________________________________________ _______________
Off topic but i have this question to: benefits of stroking a motor??? I tried searching but cant seem to find this.
Old Nov 8, 2006 | 08:03 AM
Billdog350's Avatar
A friend put down 413 SAE rwhp on an 2000 C5 M6 with LS6 intake, LT's and Corsas. Everything else was stock including heads and throttlebody. With an auto it sounds like you'd be a bit below 400...but close.
Old Nov 8, 2006 | 09:11 AM
wilddawg's Avatar
comp cams XER lobe 222/224 on a 114 and 110plus 4 581 lift use 7.425 push rods should get you there this is a custom grind
Old Nov 8, 2006 | 10:17 AM
Kraest's Avatar
That's not going to be around 400 rwhp through an auto.
You'd need to start looking at bigger cams if you want to make 400 rwhp through an auto. Something in the 23x/23s range.
Mike
Old Nov 8, 2006 | 01:03 PM
Sigforty's Avatar
My friend just did 400 with an f13 through an auto.
Old Nov 8, 2006 | 06:39 PM
slow trap's Avatar
the t2 or ^ will get you very close.400 rw through an auto is alittle more difficult but anything 390 + i'm sure would be a good running setup. remember the bigger the cam you put in the less optimum that 3400 stall will be.
Old Nov 8, 2006 | 09:49 PM
SMAX's Avatar
i did 386hp with a 233/239 595/605 112lsa, bbk intake and 80mm tb, lt's, true duals, tci ssf 3500 2.5str, 3.73's and 26x11.5 hoosier qtp's. i love this cam. it pulls hard and sounds nasty.
http://www.youtube.com/watch?v=fiS3_D8JPUQ
http://www.youtube.com/watch?v=eLTv-r0gA7A
Old Nov 8, 2006 | 11:29 PM
SOMe WS6's Avatar
i made 401 with the F13
Old Nov 9, 2006 | 02:50 PM
sonicbaloo's Avatar
We have an auto GTO with our AZPS 02 camshaft that made over 400 rwhp. This was done on stock heads with LTs. Give us a call.
Chad
