Patriot StageII vs AFR 205
Old 11-09-2006, 02:50 PM
Mike516882's Avatar
Default Patriot StageII vs AFR 205
So just like the title says, i am looking to get a set of heads to go along with a G5x3 cam. I see that the patriots are only 1100 bucks and the AFR's are 2500. Honestly what is the difference and what power would i gain from the AFR's that i wouldnt get from the Patriots. And would LS6 heads work on the LS1 becasue then i could go stage 3 heads? Thanks in advance guys.
~Mike
Old 11-09-2006, 03:02 PM
JZ'sTA's Avatar
Really you need to do some more research.
Everyone has different oponion's.
A stage 3 head is no good for your motor size/combo so rule that out.
I personially would look into AFR/Patroit/ETP/Trickflow/TSP/TEA/Dart.
Thee are a ton of great options.
Old 11-09-2006, 04:45 PM
pdd
pdd's Avatar
Old 11-09-2006, 05:30 PM
WS-Sick's Avatar
LS6 heads do work LS1's, Mike.
Old 11-09-2006, 06:10 PM
Blue02Ws6's Avatar
If you are looking for one of the "Best bang for the buck" heads, check out Texas Speed's Stage I Ls6 head. If you have money to burn check out Trickflow. I think TSP's terminator heads are also a great middle of the price range choice also that has been right there with the big dogs.
Old 11-09-2006, 06:20 PM
TXZ28LS1's Avatar
if your going with a g5x3 cam, then go with the afr heads. i think the guys at L.G. recommend the afr heads with there cams anyways. but i would like to see a side by side performance difference between the 2.
Old 11-09-2006, 06:54 PM
Mike516882's Avatar
this is honestly the best site, there are no bullsh1ters and i like that, thanks for all the fast responses! I think ill look at the trick flows and the TSP's the AFR's cant be "that" much better, who knows i could be wrong.
Old 11-09-2006, 07:02 PM
Mike516882's Avatar
and also i was just looking and im sorry i really cant just like look at something and know really whats good or whats bad about it, all of the numbers and stuff honestly i dont know what they mean, I was just told that the G5x series was a good cam to get but to tell u the truth i know absolutley nothing about it. i need some pointers! I was looking and i know some people talk about the torquer cams from Texas speed, i seriously just need help. I am new to the whole cams thing. i know exhaust and headers and intake and bolt ons but on internals im not going to lie i am lost, i need some pointers.
Old 11-09-2006, 08:23 PM
eamador11's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Old 11-10-2006, 08:57 PM
Gunnar@Patriot's Avatar
We actually have a special on CNC 243 castings for $995 per pair, assembled. These heads are a quality product and will make great power. If you have any questions, please let us know.
Old 11-10-2006, 10:56 PM
BigDB's Avatar
the patriots are the best bang for the buck. the reason the other heads like AFR, Trick Flow and Dart ect are pricier is because they are a different casting then the Partiots. Patriot uses LS6 castings and puts there touches on them to flow better than stock. The others flow better then stock but have reworked combustion chambers and runners, mostly having the same internal volume as stock but increasing velocity. They do this by designignthere own casting, thus increasing the retail value. I was very surprised that the TrickFlows' flowed better then the AFR' not by much on the intake but the exhaust trickflow killed them. Hope any of this helps.
