6.0L Aluminum Heads Problem
Guys here's what I'm looking at.
I have a set of 6.0L D shape heads for the 6.0L we're about to install in my 00 Silverado, but I also have a local race engine shop with a set of ported & polished stock valve LS1 heads they will sell me for 1k. I think they flow'd like mid 280s at .500 so they aren't brutal flowing, but they would probably work nice.
Should I buy the ported heads or just shave the 6.0L heads & call them good? Joseph says we're going to do our own light port job on the 6.0L heads, but really he doesn't have the time to sit & port my heads. From a money stand point 1,000 isnt all that bad because I will be able to sell my 6.0L heads for about 400 so I'm only out 600 for ported heads....The cam we're going with is the 216 220 compcam <img src="images/icons/smile.gif" border="0">
OPINIONS!!!
OPINIONS!!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
up!!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
It really depends on the quality of the LS1 head port job. If it's a solid honest high velocity, etc. etc. 280cfm then that would probably work better than the milled 6.0. It could just as easily be a hogged out motion killing 280 which will be MUCH worse.
Does the head shop have any other examples of their heads out there for you to gauge their quality against?
Chris
[ November 19, 2001: Message edited by: ChrisB ]</p>
Chris
I wouldn't do it, honestly. The LS1 head (any casting really, but especially the LS1 because of the revised valve angles, etc.) has it's own set of "tricks". They might be awesome, have caught them all, and have a set of heads ready to rock - but I wouldn't bet on it.
Flow numbers don't really tell the whole story is the problem though. Unless they will give you some kind of guarauntee I would say it wouldn't be worth it - to stick with your 6.0 heads.
Chris
Chris
LSxGuy widda 9sec Mustang
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I vote 6.0L heads. Not saying anything bad about the ones who ported them, I know them well. They DO know cylinder head porting and engine building better than anyone else I have ever met. They built 460 race engines last year alone, at least 40 of them were 960hp 555cid BBC engines that go for about 20K each. <img src="images/icons/shocked.gif" border="0">
They themselves have no need from a $ standpoint to do anything LS1 related and have been sitting on these heads for almost 2 years.
Its there first set of LS1 heads <img src="images/icons/frown.gif" border="0"> I will get the flow #'s
Jason
Jason
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
