Spark plug question.... just a quick easy one
Old Nov 19, 2001 | 08:22 PM
QuikSSilver's Avatar
Default Spark plug question.... just a quick easy one
I went to napa tonight and they told me that TR55's are for the v-6 only(I saw the application book myself)
everyone talks about them so I want to give them a go....
so my question is what the difference between TR55's and TR5's as napa told me the one's I want are actually the TR5's,
maybe a dumb question but.... hey ya don't know unless you ask <img src="images/icons/smile.gif" border="0">
I have the TR5's but wanted to see before i put them in!!
Hopefully tonight....
Old Nov 19, 2001 | 08:31 PM
99 Black Bird T/A's Avatar
Default Re: Spark plug question.... just a quick easy one
NAPA...LOL!!!
They are full of it.
The TR 55's don't really care if they are in a 4 cylinder, a V6 or a V8. At Advance Auto they almost got upset when they realized I was getting TR55's for my T/A and not for an import, they keep saying 4 plugs right and I keep saying no 8 plugs...
The TR55's worth very well I've had NGK's TR55's in my car for over a year and many other on the board way longer than that.
Old Nov 19, 2001 | 08:49 PM
turbo's Avatar
What would be better for a car with all bolt ons and a cam? TR55s or TR6s?
Casey
Old Nov 19, 2001 | 08:56 PM
ok my next question.....
No on the TR5's ..... damn napa!
Now I gotta go tomorrow and get the other one(TR55'S)?
Old Nov 19, 2001 | 09:20 PM
TTT, I know I'm being impatient but I wanna get going on this tonight if i've got the right plugs
Old Nov 19, 2001 | 09:29 PM
CMNTMXR57's Avatar
Hmm, I have Tr55's in my V8!
Old Nov 19, 2001 | 10:03 PM
monSSter1191's Avatar
Napa doesn't know what they're talking about. TR-55's will work, best damn plugs period! <img src="images/icons/smile.gif" border="0">
Old Nov 19, 2001 | 11:47 PM
allright, thats what I thought, thanks!!
Old Nov 20, 2001 | 01:34 AM
Crazyquik's Avatar
Just go make up a car, tell them you need 8 TR55s or whatever for a 1963 Alfa Romeo 138 Type S-54 then they'll look it up and wont be able to find it in thier book (because it doesn't exist) so then you ask them to just go look on the shelf <img src="images/icons/smile.gif" border="0">
Old Nov 20, 2001 | 08:55 AM
Raughammer's Avatar
D(irecto)r Pepper
NGK TR55 Stock # 3951 .059 Stock heat range
...I would recommend these plugs to someone who lived in a colder than houston climate.
NGK TR6 Stock # 4177 .035 One step colder than stock
...These are what I recommend to most H/C users... in addition to nitrous users. The colder plug will help fight detonation. I recommend the gap to be set at 50 thous for most H/C cars.
NGK TR5 Stock # 2238 .039 Stock heat range... ...some folks who use nitous like these plugs. And they DO work well in that situation... provided the "shot" isnt TOO large. I personally would still recommend the TR6's over them for the extra protection
NGK TR55VX Stock # 2885 .050 Platinum stock heat range . ...I dont like them or recommend them for an LS1 enthusiast. Platinum retains heat....this is BAD as far as detonation goes.
Good luck.
Old Nov 20, 2001 | 10:37 AM
turbo's Avatar
John most people ive seen been gapping the TR6s at .044? Is .050 better or what?
I dont know what to gap them at?
Casey
Old Nov 20, 2001 | 10:55 AM
CMNTMXR57's Avatar
Stock gap is .060, performance gap would be in the .040 range. I split the ground evenly and went .050.
Old Nov 20, 2001 | 10:58 AM
Raughammer's Avatar
D(irecto)r Pepper
If you can get away with it. .50 would be better. I ran into spark probs so I reduced my H/C spark plug gap to .44 thous.
That small of a difference most users wouldnt notice. But when your looking for every little 10th of a HP.
Experiment. Find what works for YOUR car.
Old Nov 20, 2001 | 10:54 PM
[quote]Originally posted by Raughammer:
<strong>If you can get away with it. .50 would be better. I ran into spark probs so I reduced my H/C spark plug gap to .44 thous.
Experiment. Find what works for YOUR car.</strong><hr></blockquote>
After using TR55's at 55 and having them work great, I tried TR6 at 45 for my Bolt-On car. TR6 at 45 was way too tight for my bolt car...which as mentioned above is better for a Heads and Cam car...my car lost 6rwhp on the dyno and about 3 miles per gallon. I've went back to TR55's they are at 57 right now mpg is the best to date and I'll dyno soon, I think my lost ponies will be back.
Old Nov 20, 2001 | 11:45 PM
turbo's Avatar
So what would be good with All bolt ons and a C1"Hammer Cam" ? TR6s? Remember im on stock heads still.
Casey
Old Nov 21, 2001 | 09:35 AM
Raughammer's Avatar
D(irecto)r Pepper
[quote]Originally posted by turbo:
<strong>So what would be good with All bolt ons and a C1"Hammer Cam" ? TR6s? Remember im on stock heads still.
Casey</strong><hr></blockquote>
Since your compression ratio is stock. Maybe just a touch less because of the more than stock overlap of the Hammer cam. I would have to give the nod to the TR55's on a 50 thous gap. Now that is off the cuff and with out experimenting...and within those parameters, that is all I can give. Used on a bolt-on motor, that worked for me. And from how you described your motors goals as.... it "should" work for you. (IMO)
Run the largest gap you can with no spark problems. The larger flame kernal "should" produce a larger/more powerful explosion, there by generating more power. (IMO)
Campbellini <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
[ November 21, 2001: Message edited by: Raughammer ]</p>
Old Nov 21, 2001 | 10:48 AM
turbo's Avatar
Thanks John. I guess I will try the TR55s. Thats what I was thinking of doing anyways.
Casey
