Results with ETP heads.
Old Dec 10, 2006 | 02:05 PM
  #261
mullenh's Avatar
Default ahh.. i see the screw-up fairy has visisted us again.
Originally Posted by 52172
You are the only one in the WORLD claiming a fast will not ALWAYS make more power than an ls1/2/6 manifold. I think you are ignorant. We all think you are ignorant. Just for making such a statement.
since you are speaking for all of us rev jackson please tell us what do you base you expertise on? the internet?
Old Dec 10, 2006 | 02:17 PM
  #262
SS4Matt's Avatar
no kidding...just when all the bashers were out of this knowledgable thread...one had to open their mouth again
Old Dec 10, 2006 | 04:04 PM
  #263
Sean Collins's Avatar
The know it all's know it all
Originally Posted by PREDATOR-Z
It is not because he hasn't been here long enough.
It is the fact that he has no data to back up his claims.
The major claim is that the FAST is junk, that the LS2 outpowers it and that he lost so much power swapping various ones on setups.
Too much data showing otherwise. It is possible that a "certain" cam grind is just not matching the dynamics of that intake, that can happen with heads etc...
But to say that the LS6 is superior as well as the LS2 is just not true.
Components mismatch, yes, I agree with that, everyone knows that one of the most common errors is doing so and making less power.
Now is the FAST "LORD" of all intakes, no. But it makes the power needed with the right cam specs and heads, more than a LS6 or LS2 (in stock forms).
The LS2 is a good intake but it needs modifying, ie: porting. The Aussies have proven that and once ported the LS2 does outdo the FAST. The aussies even designed a costom tool to port the LS2. Now that is innovation.
Bottom line, we go back to the magic word "COMBO". properly matched with the right parts, the FAST has it place in the market. still too darn expensive though.
I throw down the challenge as to what data i am witholding ??? those are the best avg runs in the dyno charts posted. Best ls6 best Fast. Secondly I say that most of your data is garbage. You guys are extremly hungup on a bad dynomemters. dynojet dynos just don't measure power accurately.Its not a new problem its an old one. I'd be there aren't but maybe 4-5 head/cam 347s on this site that could make more then 410 hp on a mustang 1750de at 1100 ft above sea level.
But go ahead and stop thinking. I am not making a claim the data is in the thread look at it for yourself. The Engine lost HP and TQ !!!!!!. not a small amount either. -
https://ls1tech.com/forums/attachmen...chmentid=80079
Old Dec 11, 2006 | 06:22 AM
  #264
PREDATOR-Z's Avatar
Iam talking about:
1- Full specs of setup (including cam specs)
2- Tuning specs (timing, AFR etc...)
How can any one agree with you if these info are not available and most of us do make more power with that intake?
read J-Rod's post, that is one of the posts that makes the most sense. something is definately not right (obviously) but where? That is the question, and is that intake really to blame?
Old Dec 11, 2006 | 11:37 AM
  #265
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Why would the elevation matter if you correct it properly? We have two 1750's local to us. We've dyno'd on one of them , and made more than 410... The other thing is MPH. The car is running 128 in over +2000 DA.
The Ls2 got a bad rap from A-B testing done early on a controlled engine dyno where it lost power. Folks ahve begun to port them and fix all the various issues witht hem to get them on par with say an LS6 intake.
Did you see the threads on gearchatter which addressed this?
Old Dec 11, 2006 | 12:13 PM
  #266
which version of software ?? powerdyne or the older md7000 software ?? make a difference the newer powerdyne software corrects to dynojet like numbers.
I could see the ls2 intake needing some porting due to the modling flash in the plenum area but again cam specs will have an impact on how well any fo the manifold perform.
Old Dec 11, 2006 | 12:15 PM
  #267
Iam talking about:
Read not gonna happen. AFR is best AFR for power reagrdless. You idea of the proper AFR may not be something the engine likes or wants. Range of AFR from 13.4-12.0 were tried with both intakes. Engine preferred 12.8:1 overall. Timing was at total 27btdc with both intake and had negliable affect on output from 24-29 but 27 seemed to be the best in terms of avg tq under the curve.
Cam specs are not something i will hand out freely.
Old Dec 11, 2006 | 12:45 PM
  #268
PREDATOR-Z's Avatar
But that is one area that could be the culprit, you yourself admited that the "LS2" with "proper" camshaft will shine (while if you just slap one on a stock motor it will loose power {for exemple}).
That is why I refer to J-rods post, that the intake might not be to blame.
We have seen that cam specs also have different power potential with different heads, take AFR 205s, they prefer traditional splits over reverse or no splits for that matter. So someone running a set on a reverse might just come out and say, AFR205s are crap I only picked 10rwhp over my ported LS6s, get my drift
This is where we do not agree with your comments.
Old Dec 11, 2006 | 12:52 PM
  #269
STRIPSTAR's Avatar
Well, I dont see why you are arguing with him about the FAST's. He is questioning TSP, Tony Mamo and Don Kinder and acting like they dont know what there doing???? They forgot more than this dude knows about lsx motors IMO. - We've know Slowhawk and TSP and there cars for years. Ive never heard of this guy or his shop.
Old Dec 11, 2006 | 12:55 PM
  #270
PREDATOR-Z's Avatar
Yeah, agreed, because we know better, BUT there are some "Newbies" actually believing what he says
Old Dec 12, 2006 | 07:19 PM
  #271
Notime383's Avatar
Some stated that the intake (Fast) may not be the culprit, in Sean's tests, becaused he has cammed his set-up for LS2 LS6 Intake and possibly not the FAST! Does anyone have a properly cammed FAST set-up that's comparable to Seans set-up? CID, Heads, Comp, etc.. The only way to make these comparisons are to have everything else be as close to equal as possible, otherwise it's just talk! I think Seans onto something (as we all know cam timing is important) He needs to properly cam a FAST intake, and discuss the result! Just MY .02!
Old Dec 12, 2006 | 07:24 PM
  #272
MeentSS02's Avatar
Kleeborp the Moderator™
I don't think Sean is on to anything at all IMO. He has made an *** out of himself in this thread, and has done it in another thread in the drivetrain section (look for the title including CF driveshaft gains). He talks about things he clearly does not understand, and tries to pass off his incompetence by saying that no one else knows what they are doing. I have yet to see him contribute anything useful to any discussion he's been in.
Old Dec 13, 2006 | 07:42 AM
  #273
52172's Avatar
Roger that he loves to mention harmonics and wave pulses whenever he discusses anything.
Old Dec 13, 2006 | 07:06 PM
  #274
Notime383's Avatar
Old Dec 14, 2006 | 02:56 AM
  #275
Zach@Texas-Speed's Avatar
Old Dec 26, 2006 | 09:25 PM
  #276
429 Mustang's Avatar
Originally Posted by Zach@Texas-Speed
What the hell are you doing eating popcorn when you were supposed to have posted results of your intake swap???
And where is Sean's 3 car test results???
Old Dec 26, 2006 | 09:34 PM
  #277
gtodoug's Avatar
LOL
dougie
Old Dec 28, 2006 | 08:43 AM
  #278
senicalj4579's Avatar
I'v been wondering the same thing. Where are the results?
Old Dec 28, 2006 | 09:49 AM
  #279
Haven't been able to get the required intake manifolds for the testing. Working on it. When i can i will finish this up and post the results.
Old Dec 28, 2006 | 09:51 AM
  #280
Your a moron. How do you lkike that. CF driveshafts are junk. FAST intakes aren;t far behind IMO. The data is there. Maybe you just read **** on the internet and assume it to be correct.
