Cam Swap hell...
Old Nov 11, 2006 | 01:40 AM
ReedBooth's Avatar
Default Cam Swap hell...
So just before we get the cam out, we go to slide the lifter tools in. passenger goes in fine, driver side goes 30% in and STOPS. What in the hell could have caused this? has anybody ever heard of this problem?
Old Nov 11, 2006 | 01:48 AM
mvvette97's Avatar
yep, I had to grind a small flat spot along one side of the rod all the way to the end.
Old Nov 11, 2006 | 02:30 AM
rollinna65's Avatar
Also, just spin the cam around while you're sliding in the tool. A lot of times the worn out lifter trays can't hold the lifters up.
Old Nov 11, 2006 | 05:22 AM
ReedBooth's Avatar
Did the spinning trick, along with plenty of sanding on the edge of the tool and the little bastard still wouldn't slide in.
On a side note, we DID manage to get the old cam out and the new one in using the Russian Roulette method . I'm still curious as to why that one lifter just didn't want to co-operate.
Couple hours away from first fire, pray there is nothing wrong with any valvetrain components.
Old Nov 11, 2006 | 05:51 AM
Mr. Bungle's Avatar
Man you are lucky if you used the pull, poke, and pray method. I had a buddy do that and dropped a couple of lifters as soon as the old cam came out. Good luck let us know how it went.
Old Nov 11, 2006 | 08:55 AM
ty_ty13's Avatar
7 Second Club
i used 16 pen magnents
Old Nov 11, 2006 | 09:18 AM
Sean Collins's Avatar
The know it all's know it all
Take out the pushrods and crank the engine over for a few seconds. Those babys stick nice and solid in the lifter tray when you do this. I also have a magnetic bar i made up to that works pretty good its just a pita with the Fcars to use. Either way the lifter holder tool I have works on some blocks and yet not on others.
Old Nov 11, 2006 | 04:12 PM
STL2SLO's Avatar
They wouldnt work in my 98' car or a buddys car (98' also). We took the chance and were lucky without using them..
Old Nov 11, 2006 | 09:11 PM
byler900f's Avatar
those tools work pretty well for the most part. just spin the hell out of the cam and try again.
Old Nov 11, 2006 | 09:38 PM
DaddySS's Avatar
The left side clearance is much tighter, gring/file the tool until it just slides in. BTW I made my own from aluminum rod stock - a few bucks at home depot and about 30 minutes work with a grinder and flat file.
