Got the heads and cam dynoed today...
Old Nov 24, 2001 | 05:19 PM
TrahnZam WS6's Avatar
Default Got the heads and cam dynoed today...
Took the car up to FAStech this afternoon with the new GTP heads and 223/223 cam.
Pull # / RWHP / RWTQ
1 / 408 / 402
2 / 411 / 403
3 / 412 / 409
4 / 414 / 409
5 / 418 / 411 <-- <img src="images/icons/shocked.gif" border="0">
411 rwtq is the most I have heard for a heads cam M6 car! The tq peaked at 4800 rpms and the hp peaked at 5700, low for a 223/223 112 cam. I was only advancing ~20 degrees of timing, 02s are showing a tad rich at .920s, but you really cant trust that. Hopefully I can get it peaking higher via LS1 edit. Let me know what you guys think.
[ November 24, 2001: Message edited by: TrahnZam WS6 ]</p>
Old Nov 24, 2001 | 05:27 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Got the heads and cam dynoed today...
Very nice numbers! <img src="images/icons/grin.gif" border="0">
Old Nov 24, 2001 | 06:02 PM
ChrisB's Avatar
Looking good! I think it's also worth pointing out again that the HP peak was at 5700rpm! 418rwhp at 5700rpm in itself is pretty good! I agree though, you should be pulling a few more rpm than that - just gives you something to do with your free time <img src="images/icons/smile.gif" border="0"> And yeah, 20 degrees of timing definitely isn't optimal!
Chris Bennight
Old Nov 24, 2001 | 06:06 PM
TA_2001's Avatar
Darn IT I missed that one.. I had to come home
and put out xmass lites..
Great Job
Terry today 351/364 at fastech.
Old Nov 24, 2001 | 06:19 PM
y2kz28's Avatar
Those are great numbers!! I definitely have to get dynoed again soon. I've had at least 50 people ask me what I'm putting down at the rear wheels, and I tell them "around 400". Stock I ran 316rwhp/327rwtq, so I hope I'm right. Sure feels like at least 400 <img src="images/icons/smile.gif" border="0">
Old Nov 24, 2001 | 06:33 PM
madskilz's Avatar
Just curious but what did you gain from the heads/cam combo?
I thought you were close to 400rwhp with the mods you had before did heads/cam.
Regardless, those are some excellent numbers!
Madhu
Old Nov 24, 2001 | 06:44 PM
FigsZ28's Avatar
Nice #'s Those look familiar <img src="images/icons/wink.gif" border="0"> Ive got some grotts on the way to catch me up on the TQ tho, my macs arnt cutting it <img src="images/icons/frown.gif" border="0">
Old Nov 24, 2001 | 07:04 PM
ABNRNGR (Aka Dean)'s Avatar
very nice balance of hp/tq. If your timing numbers are accurate, there is a lot more hp in this setup. I've seen my car dyno 20/18 higher with 0 vs 3.9 KR
Old Nov 24, 2001 | 07:15 PM
Thanks for the compliments guys! The cam was installed dot to dot, and I really doubt it was a misgrind, so Im hoping there is another 20 rwhp in the combo. Ive got some more tricks to try like teflon tape on the rocker arm bolt threads to prevent oil from leaking into the intake ports of the heads, setting the fans to come on a tad later, timing tricker, adjusting the translator etc...
TA_2001: Make sure your numbers are SAE and not STD. FAStech's dyno operator accidentally had it turned on to STD and one of my pulls was 427/420! <img src="images/icons/grin.gif" border="0">
Old Nov 24, 2001 | 07:18 PM
[quote]Originally posted by madskilz:
<strong>Just curious but what did you gain from the heads/cam combo?
Madhu</strong><hr></blockquote>
Even though my car is far from optimal tuning for the new heads&cam, I have still gained 20 rwhp and 33 rwtq. I expect a decent gain in power once I get my fuel and timing figured out. Right now I am shooting for 430+/415
<img src="images/icons/cool.gif" border="0">
Old Nov 24, 2001 | 07:38 PM
[quote]Originally posted by TrahnZam WS6:
<strong>Thanks for the compliments guys! The cam was installed dot to dot, and I really doubt it was a misgrind, so Im hoping there is another 20 rwhp in the combo. Ive got some more tricks to try like teflon tape on the rocker arm bolt threads to prevent oil from leaking into the intake ports of the heads, setting the fans to come on a tad later, timing tricker, adjusting the translator etc...
TA_2001: Make sure your numbers are SAE and not STD. FAStech's dyno operator accidentally had it turned on to STD and one of my pulls was 427/420! <img src="images/icons/grin.gif" border="0"> </strong><hr></blockquote> Do you feel your getting oil in the intake from these bolts? I believe if the seals on them are good they should be ok right? I think I'll just get 8 new bolts and install them or do we need to seal them better?
Old Nov 24, 2001 | 07:44 PM
Bout'ItZ28's Avatar
nice #'s
what are the cam specs lift, duration?
Old Nov 24, 2001 | 08:08 PM
SSBoy's Avatar
Those Are Very Nice Numbers. Congradulations on your Results! Makes me want to get GTP even more now <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Nov 24, 2001 | 09:42 PM
[quote]Originally posted by Bout'ItZ28:
<strong>nice #'s
what are the cam specs lift, duration?</strong><hr></blockquote>
Its a new House of Speed grind. Email Sean Gustin at silverpig99@earthlink.net for details about the setup.
Old Nov 24, 2001 | 09:44 PM
[quote]Originally posted by Dean:
<strong> Do you feel your getting oil in the intake from these bolts? I believe if the seals on them are good they should be ok right? I think I'll just get 8 new bolts and install them or do we need to seal them better?</strong><hr></blockquote>
One of my friends with an MTI stage 2 package put teflon tapes on his threads and reported that his car smoked less, gained 2* of timing and ~8 rwhp.
Old Nov 24, 2001 | 10:51 PM
TAMUz06's Avatar
That looks a hell of a lot better, Nick. Congrat's on the numbers, lemme get my cam in and let's hit the Tollway. <img src="images/icons/wink.gif" border="0">
Old Nov 24, 2001 | 11:09 PM
[quote]Originally posted by TAMUz06:
<strong>That looks a hell of a lot better, Nick. Congrat's on the numbers, lemme get my cam in and let's hit the Tollway. <img src="images/icons/wink.gif" border="0"> </strong><hr></blockquote>
Sounds like a plizzan Jim, I havent dusted a Z06 in a while <img src="images/icons/grin.gif" border="0"> I would get one too if they didnt weigh more than my WS6 <img src="images/icons/cool.gif" border="0"> <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Nov 24, 2001 | 11:32 PM
VINCE's Avatar
Shorty Director
Nick that is awesome.. I could only dream my car comes within 10 rwhp and 10rwtq.. Dec 16th I will have some new #'s...
Old Nov 25, 2001 | 12:00 AM
Thanks Vince! What heads did you decide to go with? You upgrading to a HoS cam? <img src="images/icons/smile.gif" border="0">
Old Nov 25, 2001 | 12:34 AM
VINCE's Avatar
Shorty Director
I am going to leave the vendor unnamed.. I am going to keep the T1 cam.. I do not drag race enough to warrant changes as of yet to the cam.. I am still undecided on the rear gears. I think I am going to go with the 3.73's..
