ASP Crank Pulley.....Worth it?
I have heard anywhere from 5 to 10 rwhp, for about $220..
any thoughts?
thanks for the help...
I would say they are worth it, people usually see a tenth improvement in the quarter mile....
And the only problems would be charging...that all depends...
Sean
I went to the dyno the next friday and it showed no difference in HP. Although I can feel a huge difference in the way the car continuously pulls.
I am going to try a different dyno place that has a new dynojet and see if my numbers change at all.
I would recommend them as a good mod. no charging problems with the alt pulley either, but lunaticTA who has a a4 has been saying that in traffic its falling well into the yellow on the volt meter.
Thanks
Jay
<strong>Is it ok to run the ASP pullies on a car that's nitrous equipped? (6 speed car)
Thanks <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" /> </strong><hr></blockquote>
Yes, perfectly fine.
<strong>well if it doesnt what belts do i need?? also do i need a new crank bolt??? i think i ordered mine around the same time that ya'll ordered yours from ASP...i ordered mine last Saturday...when did ya'll get yours in?
Thanks
Jay</strong><hr></blockquote>
What belt you need depends on whether you got just the crank pulley or also the alternator pulley. I don't know the part numbers right off hand but you might try a search here. You could also measure the length once it/they is/are installed.
A new crank bolt is best. These are TQ to yeild bolts.
Colonel is correct about the TTY bolt. Get a new one.
[ November 27, 2001: Message edited by: DARTH VETTER ]</p>
[ November 26, 2001: Message edited by: RPM WS6 ]</p>
These part numbers are for the "crank replacement" only.
NAPA Part# for the AC belt is 040378 (9/16" x 38-1/2")
NAPA Part# for the Crank belt is 060760 (27/32" x 76-5/8")
http://xs-fx.com/raughammer/ASP%20bolted%20in.jpg
http://xs-fx.com/raughammer/ASP%20bolted%20up.jpg
http://xs-fx.com/raughammer/ASP%20install.jpg
http://xs-fx.com/raughammer/asp.jpg
http://xs-fx.com/raughammer/asp2.jpg
There is more info on this mod on my web page.
<strong>Thanks for the part #'s! Looks like i gotta go get me some new belts!! Do i need a new crank bolt too??
Thanks
I have done MANY that have not used a new bolt. Yet, I DO recommend that one is used. If new, there is no need for locktight, it comes already added from GM. If used... add a dab of lock tight for the added safety.
Good luck.
Campbellini
