Finished MS3 Install
Old Nov 15, 2006 | 01:44 AM
pdd's Avatar
pdd
great pics! that bastard of a lifter
Old Nov 15, 2006 | 05:26 PM
2000Hawk's Avatar
As long as you follow the instructions and don't get to frustrated you should be good to go. Just torque everything down, set a time frame that you wont have to rush to meet the deadline, and just relax. Here in Miami its hot as **** so my engine temp. gets as high as about 228*-230*, and thats in heavy traffic. Oil pressure stabilizes in the itself around mid to high 30s. Idles pretty good, stumbles and dies a few times but otehr times it stumbles and picks itself right back up. Yeah that lifter was a son of a bitch, thank god he didn't fall. Thats why the dowel rods aren't perfect.
-Joel
Old Nov 15, 2006 | 05:29 PM
2000Hawk's Avatar
And this here is a must after a well done cam install:
-Joel
Old Nov 15, 2006 | 05:39 PM
lastcall190's Avatar
Awesome dude, can't wait to give mine a shot in the spring... How many miles are on your car?
-J
Old Nov 15, 2006 | 06:08 PM
2000Hawk's Avatar
My cars about to roll into the 60K mile mark. Thats the reason I changed to the TSP ported oil pump since i was already in there i might as well.
-Joel
Old Nov 15, 2006 | 06:10 PM
2KThunder's Avatar
Did you degree the camshaft after install? I just skimmed your text didnt see it. Thanks,
John
Old Nov 15, 2006 | 06:14 PM
2000Hawk's Avatar
Not really i just followed the LS1 How To instructions and aligned the dots. Whats the reason of degreeing the cam if i may ask?
-Joel
Old Nov 15, 2006 | 06:31 PM
NxLS1496's Avatar
with a good tune will the a/c still be functionable with an ms3 cam?
Old Nov 15, 2006 | 06:48 PM
Detroitmuscle's Avatar
You only have to degree a cam with an adjustable timing set the LS2 is not adjustable. With a good tune you can use a/c all you want my car drive just fine with it on.
Old Nov 15, 2006 | 08:52 PM
NxLS1496's Avatar
great, thanks.
Old Nov 15, 2006 | 10:08 PM
2000Hawk's Avatar
If i turn on the A/C now the idle drops i bit like it wants to die, but a tune will fix that with no problem.
-Joel
Old Nov 16, 2006 | 02:39 AM
  #32
MiaSSmaro98's Avatar
congrats joel cant wait to see it on the december meet Alex
Old Nov 17, 2006 | 05:32 PM
  #33
z062424's Avatar
How did the tune go? How is the car running? Any stalling problems with the new cam?
Old Nov 17, 2006 | 07:16 PM
  #34
2000Hawk's Avatar
Well i just got back and the car runs great. Ryan @ Rev Extreme *Tampa* did the tuning. Hes a real cool guy was explaining things to me using HP Tuners where everything should be and what parameters he will be playing with. The shop was bad-***, i didn't want to leave. First dyno run was:
Max Horsepower-382.92
Max Torque-359.14
A/F-13.15@6300RPMs
The weather was 68.27 degrees *F with 21% Humidity
He ran it on the dyno 6 times playing with the timing and a/f. After the 5th dyno pull he gave it an hour cool down and on the final pass it came with:
Max Horsepower-386.64
Max Torque-367.01
A/F-13.47@6550RPMs
He set the idle at 950rpms, at times it seems like it wants to die but then the rpms jump right back up to 950. I have no complaints whatsoever. I knew i was going to lose a good amount of low end torque, but let me tell you when you take this baby up to 6500rpm you better sit back and hold on.
-Joel
Old Nov 17, 2006 | 07:54 PM
  #35
z062424's Avatar
What was your baseline number? Any stalling at lights? Just curious.
Get your video camera out!
Old Nov 17, 2006 | 08:49 PM
  #36
Very stout numbers I bet she rips very nicely now.
Old Nov 17, 2006 | 09:00 PM
  #37
cws T/A's Avatar
I know what you mean I retarted my cam with a ls2 and made 900 tq ft at da spool and Thats about it .
Guess you shouldnt buy an adustable timing set huh ..more work and we dont want to do more work .
read post # 10 & 11 https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Old Nov 17, 2006 | 09:07 PM
  #38
sidewayz28's Avatar
shouldnt a ms3 dyno more? i dynoed higher with a much smaller cam. confused here??
Old Nov 17, 2006 | 09:21 PM
  #39
cws T/A's Avatar
no ls6 intake I presume . low dcr .. killed it ordering a 113lsa looking forward to the 350 shot. come on thats what the cams for I got the magic **** ah crap .. somebody stop me
Old Nov 17, 2006 | 10:30 PM
  #40
mvvette97's Avatar
what springs did you use? Did they fit right in or did you have to set them up?
