Dry sump kit!!
Old Nov 18, 2006 | 10:14 PM
LASTLS1's Avatar
6 Second Club Moderator
Default Dry sump kit!!
Who has them and how much? Post or pm please.
Thanks, Andy.
Old Nov 18, 2006 | 11:08 PM
FormulaFire's Avatar
I'd like to know as well!
Old Nov 19, 2006 | 01:27 AM
hesham's Avatar
Thanks, Andy.
http://www.w2wpowertrain.com/pc-121-...-sump-kit.aspx
Old Nov 19, 2006 | 02:01 AM
LS2Camaro's Avatar
You going to run a Dry Sump Oil System LASTLS1? At what point do you think it is recommended to go Dry Sump? I was thinking about picking one up as well, but not sure if it will be needed yet.
Old Nov 19, 2006 | 02:15 AM
Dragframe's Avatar
trick stuff
Old Nov 19, 2006 | 02:33 AM
Louis's Avatar
There really isnt a "Kit" per-se, but there are pans and pumps out there. Drysump.com is proven, dailey engineering is pricey and that is about all that make them in a readily availible setup.
Its really a per application deal. 2 stage? 3 stage? 4 or 5 stage? Whats the target Vacuum? Purpose? What drive setup? how big of a tank? internal or external pressure regulator? Internal pump for pressure and 2 external stages for scavenge? or all external?
There is a lot more to Drysumps than meets the eye. Good luck, and Ill answer any questions I can.
Old Nov 19, 2006 | 10:38 PM
LASTLS1's Avatar
I'm thinking about it. I'm running 7500 rpm and I don't want any problems. I would like to run the rpm a little higher, it really wants to rev!
Old Nov 19, 2006 | 11:52 PM
LS1FC3's Avatar
Damn. $3176...Not any time soon for me. This will be great when I start racing, though.
Old Nov 20, 2006 | 12:07 AM
DavidNJ's Avatar
The ARE system is more of a race setup...Koztecki in Australia has more of a street system that allows use of A/C.
Old Nov 20, 2006 | 12:10 AM
Ferocity02's Avatar
Thats a steep price for a dry dump kit. You could probably fab up something yourself for cheaper.
Old Nov 20, 2006 | 11:15 PM
DavidNJ's Avatar
Very unlikely. You can probably get a pan from Armando for less. However, pumps are pricey, and having the right fittings to allow the other accessories and fit in a street car engine compartment is not trivial. Even in a race car it can get tight.
