difference between LS6 style heads and 5.3 heads
Old Nov 23, 2006 | 02:55 PM
erikthegoalie's Avatar
Question difference between LS6 style heads and 5.3 heads
what is the difference between all the popular ls6 style heads and the popular 5.3 heads..why would I want one over the other for a N/A car??
Is it the compression bump with the 5.3's people like??
Happy T DAY!
Erik
Old Nov 24, 2006 | 06:24 AM
PREDATOR-Z's Avatar
Untill last year, the 5.3 was the budget option for ported heads. LS6 heads were $1200
for cores. With the arrival of the LS2, and their 243 (LS6) castings, that threw the market upside down since you could now have LS6 castings for around $450
In stock form the 243 is much better flowing. In mild ported form they are pretty much similar. A 5.3 achieves that with smaller intake runners (~220cc ported) and have a tad more velocity. It all depends on the stage of porting.
Old Nov 24, 2006 | 09:44 AM
ls2 bait's Avatar
so in ported form that would tend to say u can do a little more with the 5.3's on a stock displacement motor. u should also gain some mid range because of the smaller runners correct?
Old Nov 24, 2006 | 09:50 AM
Patrick B's Avatar
PredatorZ I am looking for a set of ls6 heads were can you get the bare castings for 450? Also what are welded chambers? I see were you can get 035 castings with welded chambers. Is that like a 6.0 head with the chambers welded? Thanks for your help.
Old Nov 24, 2006 | 10:23 AM
N4cer's Avatar
Remember: 5.3L heads offer less PTV clearance.
Old Nov 24, 2006 | 10:54 AM
PREDATOR-Z's Avatar
Patriot sells stock 243 castings for that price. The difference between LS6 243 and LS2 243 are the valves, that is all. LS2 have solid stanless valves not the sodium lightweights.
The LS6 "style" you are talking about are 6.0 heads with welded chambers to bring the cc down. Stock 035 are 72cc. By welding the chambers, they can custom make your desired chamber size. They are called LS6 "style" because they have the same runners as LS6 heads, kinda like a LS6 head with a big chamber.
Old Nov 24, 2006 | 03:43 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
This I didn't know; you could've very well just saved my *** (and motor)
Old Nov 24, 2006 | 08:21 PM
ls2 bait's Avatar
but how much less? say the cc of a 5.3 is 61ish and an ls6 is 64ish. if i get them to 60 on either head then how much difference would you be looking at.
Old Nov 24, 2006 | 10:57 PM
N4cer's Avatar
Ask the guys at a shop. They could tell you exactly. I just know that there's other reasons for the PTV clearance to be different, not just the cc of the combustion chamber. It really doesn't matter, since you'll have the heads off. Take 20min and flycut and run whatever you want.
