can someone chime in ASAP?
Old Nov 27, 2006 | 12:12 AM
dub.ya.es.SICK's Avatar
Default can someone chime in ASAP?
ok ive read multiple threads now about people contradicting eachother on rocker assembly, ok this weekend i did a PR check and all were great but on install I just used loctite on the bottom of the head on the intake bolts, I now know that this is only necessary for ported heads but I noticed there is factory loctite on the bolt heads as well but should I have put sealer or loctite on the threads, I am not driving it anymore due to the fact that Im parrinoid Ill probably pull the cover and fix it but do I loctite the threads or use sealer or is it really nothing to worry about, I would just hate my rocker bolt to back out....anybody please?
Old Nov 27, 2006 | 01:16 AM
Long Beach's Avatar
Uh, you used loctite on the intake bolts, valve cover bolts, or the rocker bolts? Im having trouble decoding what you are trying to say. sorry
Old Nov 27, 2006 | 04:12 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I didn't use loctite on the rocker bolts/poly locks. 22ft lbs. Done.
Old Nov 27, 2006 | 09:02 AM
yea on the rocker bolts do i loctite them before torqueing? whats poly locks?
Old Nov 27, 2006 | 10:08 AM
anyone else?
Old Nov 27, 2006 | 12:57 PM
BriGuy's Avatar
I've always used loctite on the rocker arm bolts. fwiw
Old Nov 27, 2006 | 12:59 PM
LITE SPD's Avatar
Thats what I did. But just alittle bit.
Old Nov 27, 2006 | 02:03 PM
5.3LJimmy's Avatar
I've never used loctite. I have only seen one set of rocker bolts back off and it was on a solid roller setup w/ T&D shaft rockers on my cousins car. I torqued them to 22 Ft/lbs and they never backed out again.(I did not assemble the first time) You could clearly hear the excess valve lash due to the loose bolts and he drove it for 200 miles that way. When I took the valve covers off the bolts were a long way from falling out. So even if the bolts do come loose you will know long before any damage would occur. But in my opinion it's not gonna happen, loctite or no loctite.
Old Nov 27, 2006 | 08:22 PM
Long Beach's Avatar
I did not use any either. I read about it on here and i think its just a personal preferance thing. Some do, some dont, like 5.3LJimmy said you will know if they come loose long before they will cause any major damage.
Old Nov 27, 2006 | 11:51 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You hope.
Old Nov 28, 2006 | 02:46 AM
Long Beach's Avatar
True, i torqued them to 22 ft/lbs and i ran it for 1 week and rechecked and they did not budge so i think im good.
