Hypertech tuning
Old Dec 28, 2001 | 07:41 PM
REC's Avatar
REC
Default Hypertech tuning
I tried doing the power tune on the HPP3 today. After I set it and took the car out for a test run it pinged really bad. I went to Amaco and put in 93 octane gas just to make sure because it had been about two weeks since I had drove the car and again it pinged. I did not get the 160 t-stat they recommend, I am still running the stock one. Could this be the problem? Thanks in advance 2001 SS
Old Dec 28, 2001 | 07:58 PM
laSSt one's Avatar
Default Re: Hypertech tuning
By all means get the 160 t'stat.Your car will like you better for it.You may want to wait until
the weather gets warmer though.If you gas is the new improved,reformulated stuff they make us run on in Texas the pinging won't go away.Hypertech is not kidding when they say it must be 93 octane or better.The only problem is the new gas is more volatile.As in it has a lower flasher so you ping more.Just take advantage of all the other good features the HPP3 gives you and leave the high perf tuning off.
Old Dec 28, 2001 | 08:13 PM
SSleeper's Avatar
Mine continued to ping even after 160 stat. When I changed out pcv valve the pinging quit. So did the oil consumption.
Old Dec 28, 2001 | 08:18 PM
LS1powerN20's Avatar
my car did the same thing, some cars just don't like the tuning for some reason. I just went back to the stock tuning.
Old Dec 28, 2001 | 09:57 PM
01Z0H6's Avatar
I just purchased one myself still in box. Will program this weekend. Am leaving the stock Stat infor winter!! I can just "Power Tune" it for now can't i?? I can always "Custom Tune" @ a later time. Right??? If i read the inst. correctly!! That is the way i percieved it.
Old Dec 28, 2001 | 11:08 PM
JohnL's Avatar
That is correct. The first question is do you want to just power tune or customize?
Old Dec 28, 2001 | 11:19 PM
MitchR's Avatar
Rec,
What other mods do you have. My 2001 SS pings with ANY induction mods. I think that the programming on the 2001's is already highly optimized and runs quite lean. Once I added a Lid and filter I had pinging. I had to add a MAFT and up my WOT fuel to +14 % - which is the max and it still pings on occassion. A free flowing exhaust and lower TStat on my car might stop the pinging - I'll know that this spring.
I would say that for your 2001 SS it is noprmal and you should run without the Power Programming.
Good Luck,
Mitch
MitchR's Avatar
ohh... I run 93 or 94 octane at ALL times. Never 92.
Old Dec 28, 2001 | 11:21 PM
MitchR's Avatar
Rec,
I see your from Richmond. One of my best friends is a Richmond Police Officer <img src="gr_images/icons/wink.gif" border="0"> He's actually in town this weekend and we are having a 30th suprise B-Day party for him. He's really loviong all the snow were getting in Buffalo <img src="gr_grin.gif" border="0">
[ December 28, 2001: Message edited by: MitchR ]</p>
Old Dec 28, 2001 | 11:49 PM
Brother J's Avatar
I've been getting away with running the power tuning with the crappy 91 octane gas in Kalifornica. 160 t-stat, 160 fan settings and the vertical PCV mod seem to rid my engine of KR. I get 28.5 advance. <img src="gr_grin.gif" border="0">
Old Dec 29, 2001 | 07:46 AM
Warlock's Avatar
I found my car actually ran better without the tuning (2000 Formula with all the air mods) I still had to buy a MAFT to stop my pinging but only because 2000's came with 22# injectors. One word to the wise. If you are an A4 DO NOT adjust your shift firmness! Everyone I know that has done it has torn up their tranny. Mine is in the shop now with a bad 3rd gear drum and bands. Hope this helps.
Old Dec 29, 2001 | 08:56 AM
REC's Avatar
REC
Thanks for all the info. Warlock,I do have a A4 and I did bump the shift firmness up, you said this is not good on the tranny. Could you elaborate a little more on what happened. Thanks
Old Dec 29, 2001 | 09:46 AM
01Z0H6's Avatar
That is one of the main functions of the Power Programmer, to bump up the firmness of the A4's!! Hypertech claims that there is less stress on the tranny <img src="images/icons/confused.gif" border="0"> Warlock, please elaborate if you will. Hell, that is one of the main reasons for purchasing one of these units is to change (upgrade) the shift points, rev limiters, etc.....
Why would they "claim" prolonged life of the transmission? ANYBODY???? Agree, Disagree, What???
Old Dec 29, 2001 | 05:41 PM
SB's Avatar
SB
Where do you find the vertical PCV mod??
steve
99ss
Old Dec 30, 2001 | 02:17 AM
Brother J's Avatar
[quote]Originally posted by SB:
<strong>Where do you find the vertical PCV mod??
steve
99ss</strong><hr></blockquote>
Look over at tech-ls1.com. I'm pretty sure that's where I found it. Its very detailed, including part numbers.
Old Dec 30, 2001 | 03:43 AM
LS1LT1's Avatar
[quote]Originally posted by PewterY2KZ28:
<strong>That is one of the main functions of the Power Programmer, to bump up the firmness of the A4's!! Hypertech claims that there is less stress on the tranny <img src="images/icons/confused.gif" border="0"> Warlock, please elaborate if you will. Hell, that is one of the main reasons for purchasing one of these units is to change (upgrade) the shift points, rev limiters, etc.....
Why would they "claim" prolonged life of the transmission? ANYBODY???? Agree, Disagree, What???</strong><hr></blockquote>They give you the choice of 25%, 50%, 75% or 100% firmness settings, I bet the first two aren't too harsh on the trans but you probably shouldn't go higher and of course you shouldn't use any if you have a shift kit installed. Raising the shift points is helpful too, but again don't go too high, could hurt the trans (and hit the rev limiter) and also slow you down. I ran better without the power tuning as well even with the 160'. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" /> <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Dec 30, 2001 | 08:59 AM
WILWAXU's Avatar
[quote]Originally posted by MitchR:
<strong>...My 2001 SS pings with ANY induction mods. I think that the programming on the 2001's is already highly optimized and runs quite lean... </strong><hr></blockquote>
Hmmm, from what I've seen... your car is the exception. I've ran HPP tuning with all the bolt-on's in 95º weather with no pinging. In fact there was no KR on the autotap.
REC I recommend running two tanks of "good" gas through the car and trying the tunning again. May have some bad gas...
[ December 30, 2001: Message edited by: WILWAXU ]</p>
Old Dec 30, 2001 | 02:01 PM
01Z0H6's Avatar
Ther is an Exxon about 12 miles from my house that sells the 100 octane gas!! It's around $3.00 per gallon though!! But it's good to go half & half!! <img src="gr_grin.gif" border="0">
Old Jan 20, 2002 | 06:56 PM
C5XTASY's Avatar
An increased shift firmness setting means you are increasing transmission line pressure. Increasing line pressure causes the transmission clutches to lock up quicker, thereby slipping less. Less slip should equal less wear of the clutches.
I don't know what the best firmness setting to run is but 50% feels pretty good and I really don't think 75% would hurt it. I'm not sure about 100%...never tried that one. I know that the Powerloader runs high firmness settings (and eliminates torque management during shifts) and several members on some of the other forums I hang out on use the Hypertech. I've never heard of a transmission failure attributable to too firm of a shift using a Hypertech (or Powerloader, for that matter).
Ed
