check gauges light flickers @ WOT
Old Jan 6, 2002 | 03:02 AM
1badmfr's Avatar
Default check gauges light flickers @ WOT
Please help. I blew my motor 6 months ago but right before i blew this happened. So the motor is rebuilt and runs great but at WOT the check gauges light flickers. Im just scared because last time this happened it went boom.
Old Jan 7, 2002 | 12:41 AM
1badmfr's Avatar
Default Re: check gauges light flickers @ WOT
please help
Old Jan 7, 2002 | 10:48 AM
Paulie's Avatar
Have you looked at the gauges when it's flickering? Could be anything: you're low on fuel, so when you nail it, enough moves away from the float so that it slightly reads at the point it would light the check gauges. Could be oil pressure, I don't recall if that's a hard MIL or not (I would hope it is!!!) or voltage as well. You could autotap everything that has a gauge and record a couple of runs.
Hope this helps.
Old Jan 8, 2002 | 12:10 AM
Chris Spiess's Avatar
I've been having the same problem since the fall. Haven't found anything yet though. Only possible issue is oil pressure on the high side at WOT and 4500+ RPM, but I haven't confirmed that as the cause.
Good luck, pleasedrop me line with anything you find out
Old Jan 8, 2002 | 12:40 AM
1badmfr's Avatar
yea I thinks its oil pressure but what do you do about that. And what is MIL
Old Jan 11, 2002 | 04:15 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Check your wiring harness plug that goes into the top of the alternator. Mine was doing this same thing once, and that plug was working itself loose. Just push it in and see if that fixes it.
Tony
Old Jan 11, 2002 | 05:23 PM
ToplessTexan's Avatar
[quote]Originally posted by 1badmfr:
<strong>yea I thinks its oil pressure but what do you do about that. And what is MIL</strong><hr></blockquote>
MIL == Malfunction Indicator Lamp
Old Jan 12, 2002 | 12:39 AM
I was playing with my car some more today. If I hold it in 2nd, about 4600 or so RPM the 'check gauges' light stays on until I get off the the throttle and the RPMs come back down bit. The oil pressure rises (obviously) but dosen't really get that high, only a bit over 60psi. What are you seeing on your pressure gauge that makes you think it's oil pressure?
Everything operates as normal, car runs as strong as usual, voltage if fine, got gas, etc. I'm with you, I really want to figure this out, it makes me nervous.
As a total shot in the dark, do you have a shift light or aftermarket tach tapped into the PCM tach signal?
Old Jan 12, 2002 | 07:15 PM
1badmfr's Avatar
I m not sure how high the oil pressure goes up. But I know its wasy to high Ill check tonight and I dont have an aftermarket shift light or anything.
Old Jan 13, 2002 | 01:37 PM
Tim 98z's Avatar
I have the same problem. Asked Last week about it. I was told its probly fluids some where? But i did notice mine does it at HOT idle also. And of coarse WOT runs. Its real dim like its not coming on fully...hmmm wish i knew ill go check the Alternator plug.
Old Nov 27, 2005 | 10:01 PM
magnanpi's Avatar
anybody fix this? mines doing it to!
Old Dec 24, 2007 | 09:45 PM
connexion2005's Avatar
bump for this as mine did it tonight! car is very stout an clocked consistent 12.7's a couple of weeks ago...seems to me like some type of short somewhere. I'm gonna check with nineball's advice and check my alternator harness and exciter wire. I had that off once when i did the motor mounts.
Old Jan 5, 2008 | 12:11 AM
to follow up on this guys it turns out that the exciter wire connector was loose...i just popped it back on and all is well.
