DIY Porting - Humbling Experience
I am a bit baffled by the loss of torque. All I changed from the previous dyno were the heads and the SVO 30#'s. I fattened up the WOT setting one notch to 2% rich to get the A/F to around the 12.5 level.
Forgot to add that I also installed 12 bolt with 4.11's and a steel drive shaft since I last dyno'ed.
[ January 06, 2002: Message edited by: Brother J ]</p>
<strong>Forgot to add that I also installed 12 bolt with 4.11's and a steel drive shaft since I last dyno'ed.
[ January 06, 2002: Message edited by: Brother J ]</strong><hr></blockquote>
This is probably where all your power went. The extra weight of the steel driveshaft and 12 bolt increased your driveline losses. I think I remember seeing something about short gears lowering dyno numbers while at the same time helping ET and trap speeds. Not too sure about that one, though.
I lost 12 rwhp between stock rear with 3.73s and the 12-bolt with 4.10 gears, and I even added a carbon fiber driveshaft at the same time! Not sure how much that was worth over an aluminum one.
Loss of torque probably came from the rearend, much like how Corvettes always show less torque than F-bodies mod for mod due to the increased drivetrain losses they have with the independent rear setup.
Tony
My current dyno results are:
362.2 rwhp
348.7 torque
<strong>so you going to go to the track this Saturday? <img src="gr_stretch.gif" border="0">
Jeff
[ January 08, 2002: Message edited by: FormulaWS6 ]</strong><hr></blockquote>
I am praying for good weather this weekend.
<img src="graemlins/gr_hail.gif" border="0" alt="[hail]" /> <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" /> <img src="graemlins/gr_angel.gif" border="0" alt="[angel]" />
