918 or PRC duals for 228R?
The PRC duals have added piece of mind but are alot more seat pressure and not really necessary for my sixed cam. The PRC dual package comes with titanium retainers and is only $100 more.
It is pretty much no brainer to get the PRC duals, but I can't keep myself from thinking that I am overdoing it with the duals and giving up horsepower.
Someone reassure me that the horsepower loss is negligable and that the added seat pressure has no tradeoff, so I can settle the battle in my head
Thanks, James.
To add titanium retainers its $150(i believe) and that means I'm paying more, unless I missed something and the 918 kit comes with Ti Retainers.
I haven't read but one post on a 918 failure and that was for a truck.
There will not be a loss going with a stiffer spring. My vote is for the dual coil springs.
Ben T.
The 918 that broke was the updated blue stripe and they always were allowed to warm up before driving on them.
Ben T.
The cam was a 230/224 .575/.55_" cam.
Ben T.
https://ls1tech.com/forums/generation-iii-internal-engine/606522-patriot-announces-our-new-gold-xtreme-spring.html
Ben T.
https://ls1tech.com/forums/showthread.php?t=606522
Ben T.
Is the addition of Ti retainers going to cost me an additional $160, which means I will be paying $60 more than the duals(come with Ti Ret.)? If this is the case, then I really can't see me not doing the Duals, unless someone who has had ALOT of experience, like an engineer at CompCams or comparable, can give a definitive mathematical reason and not just personal experience.
Parts are always going to have failures, no matter the quality assurance involved. There was a thread were a guy was busting the inner spring on his duals, I think they were manleys though.
In reguards to page 3 of that thread, I really didn't get anything definitive from it.
Quote:
Originally Posted by Studytime
"If the rest of your valve train can support the increased pressure, stronger valve springs will not affect valve control in a negative way. Valve control will only be increased.
Ben T."
Quote:
Originally Posted by Gunnar@Patriot
"The key is that your valvetrain can support the greater pressure. If your valvetrain will not, components will not work efficiently and can result in a loss of power."
Notice how a lot of the guys are justifying that you should run 918s... it's "because they are".
I could guess what a tech at comp cams would tell you if you asked them what springs to run.
Ben T.
i have 5000 miles so far with my setup, hard driven everyday, 140 miles round trips, and the springs are holding up fine. if i'm loosing some hp i won't really know, i powershift 2nd to 3rd from time to time at 6800rpm
, so i like to know they're there doing something good for my setup. Last edited by BlueGoat06; Dec 12, 2006 at 08:54 PM.
