Porting question........Intake vs. Exhaust
Now isn't it a coincidence that single pattern cams work so well especially on the ported heads? The split duration cams work better with stock heads because there is a need for more exaust flow. One more point, what yields more gains on an LS1, an LS6 intake or good set of headers?
My $.02
You may be right about the GMHTP test, but wouldn't you make sure if you were going to be in a magazine that you had the best flowing port of the best flowing heads? I'm curious how much they flowed with the LS1 intake and without an intake at all. I KNOW there has to be a restriction with the intake, or why do the shops for 1 talk about what a restriction it is and 2, some are working on their own.
And I also think that the computer has something to do with the single vs. split pattern debate.
Same head W/out intake:314 cfm, with ls1 intake:268cfm. Yes there is a loss with intake, but thats even true with short runner carb. race intakes too.I agree with you about not making head port bigger than intake opening, and keeping velocity, but dont under estimate LS6 intake. The reason i think people are looking for alternatives has less to do with flow of intake, more to do with runner length not being correct for rpm of there targeted setup.The ls6 intake has made 700hp as far as i know.
Josh
You shouln't have to choose though - have them both worked over - and this != hogging out It's all relative. They may say the intake flows "good" - where good is in respect to a set of camel hump heads, so they don't bother with it - but that doesn't mean it can't be made better - much better in fact. And the cars that are running fast aren't the ones that have heads that are just "okay".
Chris
I was talking to a guy down down in southern GA that made 412 rwhp with a similar port job that I described, and a B1 cam. A local guy did his heads and just cleaned up the intake, and ported the hell out of the exhaust. It made some good power on the dyno, but I am wondering what was left on the table by not working the intake to match. Hmmmm
