I just ordered LG G5 cam!
If the cam is big on duration both intake and exhaust you will move your powerband way up there.
I think the 112LSA cam would be a better choice if it is in the 226+ range in duration, unless of course you want to rev to 7200rpms.
Cheers,
Chris
For drag racing optimization, I would choose the 112 because the 3500 - 4000 range can be important to getting a good launch from an A4 depending upon the stall. On the street, he'll just go up in smoke with a max launch, so put the power where he can use it, which is the top end.
The 112 does make the converter feel a little tighter, so that aspect is lost with the 114.
I am going with a 226/234 557/575 lift 112LSA cam in my A4 Formula. I will let you know how the car idles etc. It is going in for its work on Feb 18th.
Thanks,
Chris
Ryan
IF the results are what we requested, it doesn't matter if the cam has the "right" numbers...
<strong>congrats....the lope is comming...did lou try to talk you into the new cam they have there?</strong><hr></blockquote>
No not at all. I was speaking with Chris about this. If he was unable to answer my question he just asked Lou. I DID ask Chris about the new cam, and he said it wouldn't be ready for 3 or 4 months. I am having my car done in a few weeks so I need IT NOW.LOL <img src="gr_eek2.gif" border="0"> I am hoping for 11.4 or better with a cage and some ET streets.
<strong>
That cam would peak at approx 6500 with 112LSA. A 114LSA would push it over 6800 and necessitate a 7200 rpm shift point. Overkill if you ask me.
Lets assume for a minute, that you are correct in the rpm estimate, 6500 vs 6800. Further lets assume that he will not shift any any higher than 6600. Whether the 114 is leaving some benefit on the table is not the question. The issue is does the 112 make any more horsepower in the relevent range of 4000 - 6600 rpm (or even 4500 - 6600 for street use) than the 114 LSA.
