Roller Rockers for the LS1?
Old Feb 18, 2002 | 08:54 PM
Black Sunshine/ 00SS's Avatar
Default Roller Rockers for the LS1?
Any available for the LS1 as a direct replacement & upgrade? Any improvements?
Old Feb 18, 2002 | 09:26 PM
steve's Avatar
Default Re: Roller Rockers for the LS1?
the stock stuff is pretty darn nice.
its already rollerized, just the tip isnt.
not much other that you can do other than the exspensive jesel or t and d shaft set ups or the crane 1.8 rockers....
just keep what ya got if your not getting to crazy with things.
steve frank
Old Feb 19, 2002 | 12:13 AM
I'm thinking of something lighter than the stock ones. I'll have to call Comp tomorrow.
Old Feb 19, 2002 | 12:22 AM
jmX's Avatar
jmX
You are thinking of something lighter? The stock ones aren't heavy. The stock rockers are roller rockers already btw.
Jesel makes some 1.7 repalcements.
Old Feb 19, 2002 | 07:59 AM
Colonel's Avatar
If you want the best get Jesels. They can be had in stock or higher ratios.
Old Feb 20, 2002 | 12:43 AM
DARTH VETTER's Avatar
I have the Crane 1.8's on my car.
[ February 20, 2002: Message edited by: DARTH VETTER ]</p>
Old Feb 20, 2002 | 05:23 AM
ChrisB's Avatar
[quote]Originally posted by Black Sunshine/ 00SS:
<strong>Any available for the LS1 as a direct replacement & upgrade? Any improvements?</strong><hr></blockquote>
None are really going to be a direct replacement - even if they were you would be changing out valvesprings to compensate for the greater lift.
If you are going to spring for them you are looking at 600+ to get into the crane's - for the same price you can have some T&D shaft rockers or Jesel sportsman's - shaft rockers are going to be much more stable and stronger than the stud mounted counterparts. Honestly you probably won't see a big difference with either, but if you are going to spend the money get the best. It will allow you room to upgrade to a solid roller setup in the future also.
Bottom line - for the price you would pay for rockers, springs, etc. you can probably get springs and a cam install (or pretty close), and that will give you a much larger gain.
Chris
Old Feb 20, 2002 | 07:25 AM
nevrenuf's Avatar
I'm very happy with my Jesels...
Old Feb 20, 2002 | 09:08 AM
Thanks for the info guys..
Chris, Cam & springs. t-retainers already on the way, although I'll have to wait to install them... TR 224-112 <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
